BMW OEM Plate Light LED's
Old 12-15-2007, 12:36 AM
  #31
my530i's Avatar
Remove some part of trunk liner inside and you can access tons of spaces. I'll order those lights on Monday.
Is part number shown on the box correct for this LED light?
Old 12-15-2007, 02:37 AM
  #32
KnIgHtCoM's Avatar
The relay is just to prevent strobing right?
Here's the parts I ordered:
Old 12-15-2007, 04:57 PM
  #33
KnIgHtCoM's Avatar
25W/30-Ohm resistor didn't work. Still got an error in I-Drive. Any other suggestions? Bigger resistor?
Is a relay an integral part of preventing the error message?
Old 12-15-2007, 08:35 PM
  #34
my530i's Avatar
I used festoon LED and you use OEM LED.
Try to reduce down to 15 ohms. If you have two of these, connect them in parallel. Try lowering resistor value with different resistor until you don't see the warning.
I'll order these two lights from Garry on Monday and test it myself.
If you like want sell me those light and I'll do the installion and post DIY for you here.
Old 12-15-2007, 08:46 PM
  #35
KnIgHtCoM's Avatar
I'll wait for you to get your lights and do testing. I'm just taking shots in the dark.
I think I can live with the error for another week, but I'm anxious to figure it out. Keep me posted of your progress!
BTW, you never answered my question. Is the relay just to prevent strobing?
Old 12-15-2007, 10:04 PM
  #36
my530i's Avatar
You did not read my post #1, did you?
Old 12-16-2007, 12:06 AM
  #37
KnIgHtCoM's Avatar
Which #1 post?
Old 12-16-2007, 09:56 AM
  #38
my530i's Avatar
Dang it! Miss a "1", post #11
Read item #1 and #2 Too lazy too type again.
Fred
Old 12-16-2007, 01:20 PM
  #39
KnIgHtCoM's Avatar
Hmmm... maybe that's why the resistor wasn't working for me then. I didn't realize the circuit needed to be closed. I thought I was supposed to tap it in-line on just the positive feed. Does it matter which sides of the resistor I connect the positive and grounds to?
Old 12-16-2007, 09:36 PM
  #40
my530i's Avatar
For the ground, it's all connected, so it does not matter. For positive side, you have to connect it to pin 85 of relay as shown.
Resistor is not polarized, meaning that either ends can be used as negative or positive.
Quick Reply: BMW OEM Plate Light LED's
