Big problem after header and intake mod..
I ve put a performance air intake kit and de-cat headers with straight through exhaust to my 04 525i today.
Picked the car up from workshop,feels good and faster.After a few miles drive I stoped a while(about 2mins) with engine running.Soon the check engine light came up and engine started to flick a bit and exhaust sounds became weird,I can feel from the steering wheel about the engine flick.I turned the car off for about 30mins then restarted again.The CEL gone and the car back to normal but soon after I drive few miles then stoped the problem came up again..
Anyone done airintake and de-cat header+exhaust had this problem before?Do I need to do something with the ECU?
Model Year: 2005
Engine: 545i
Since you had header/cat work done there might be a leak making the sensor throw a lean mixture warning. Could be that as well.
My Ride: M6 E63 Sapphire black
Z3 Coupe R4Turbo Hellrot, semi race. (670bhp)
Z3 Coupe V8Turbo design work ongoing, full race.
Sold: 545i Titanium Silver
If you delete cats without remapping your ECU, you are asking for trouble
The lambda probes are possitioned before and after the cats, guess why?
Without cats the system will pick up faulty signals and throw the CEL.
The wierd exhaust note and flicking was probably the car getting into limp home mode, to save the cats (Which you do not have ) when reading error signals from the lambda probes.
thesalboy
04-08-2015 09:13 AM
