Best Sprint Booster location?
My Ride: .
Model Year: .
Originally Posted by monsterj34' post='683171' date='Oct 1 2008, 06:57 PM
Where is the best place to put sprint booster?
Chennai, India
My Ride: 2005 545i
Frank,
Can you get some pics and a DIY as to how you hid it ? I have mine right next to the pedal and it is beginning to bother me.
My Ride: .
Model Year: .
Originally Posted by navin' post='683967' date='Oct 2 2008, 05:44 PM
Frank,
I'll take pics and circle the area where my SB is located. Post it in a few ...
Btw, still loving that RPI scoop?
Chennai, India
My Ride: 2005 545i
Originally Posted by mrfva' post='683970' date='Oct 2 2008, 03:48 PM
What I did for mine was hide above the gas pedal (top-right). There's a bit of room there, but I had to slice the carpet a bit -- not much, just enough so you fit the SB up in there. You may have to remove some of the foam padding out to make room. When you cut the carpet opening, make sure it's just a slice so that you can close it back up and put the pedal over it when you put it all back together.
I'll take pics and circle the area where my SB is located. Post it in a few ...![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I feel the car is definitely holding its rpms above 60 so driving is effortless above that.
My Ride: .
Model Year: .
Originally Posted by navin' post='683991' date='Oct 2 2008, 06:10 PM
Hell yeah, I took a colleague who drives a 335 for a drive and he was amazed at the way it pulled from 60 into 3 digits in 6th gear.
Here's a pic ... I've noted 2 areas since I can't exactly recall the location. It's one or the other. Once you get in there, you'll know where you have room. Just make sure, where you slice the carpet isn't visible once you put the pedal back in place.
![](https://i288.photobucket.com/albums/ll168/mrfva/BMW%20Random/IMG_4933-1.jpg)
I believe it's "A", just above the pedal, slightly to the right is the final location, but I had to slice around the "B" area to fit it in. It was a struggle to get it up there since I made the opening as small as possible.
My Ride: 2004 530i
premium package/active steering/auto sunshade/tiag/black dakota leather/logic 7
35% tint all around
19' DPE GT7
mine is tucked into spot B as indicated in the previous pic. I cut the carpet a bit right beside the pedal and jammed the SB in there.
My Ride: 2005 BMW 525D M-SPORT // Grey // SB attached
I found this ... might come in use for installation
http://www.sprint-booster.co.uk/how_to_ins...echeck=yes&
derooster
09-22-2015 10:10 AM
umnitza
09-02-2015 11:28 AM
spediegunz
08-30-2015 09:43 AM
