BEIKLAPPEN_B_KOMFORTSCHL has been set to aktiv, but mirror not folding from keyfob
#21
Trace file seems to be in order ... when you change VO you have to re-code (the best is process the whole car) 'cuz by adding/removing option it'll effect a module (maybe multiple modules) BUT doing so could be dangerous so at least re-init the particular module you know that is effected in this case KGM.
To re-init, code the KGM w/ a blank MAN file first so the module take default setting/value based on the VO (since you add $430 it may have different stuff) and re-adjust what you want after that.
AFAIK, no matter what NCS Expert should complete the job w/o any kind of error, in your case since it threw error obviously indicated something is not working properly.
#22
My Ride: OEM Specs - Titanium Silver, Steptronic, Premium Package, Cold Weather Package, Premium Sound Package, Dakota Black Leather, Dark Poplar Wood trim, Xenon Adaptive Head Lights, Navigation, Satellite Radio
Mods: Umnitza M5Tech Body Kit(Front, Rear and Side Skirts), Alufelgen 19/8.5 ET35 (Front) 19/9.5 ET35 (Rear), Continental DWS 245/35ZR19 (Front) 275/30ZR19 Rear, MGP Red Caliper Covers, RPI Air Scoops, BMS Power Box, FormulaOne Pinnacle Tint (VA Limits), Angel I Bright 3.0A (Bright White), R1 Premium D/S, Hawk HPS Pads, M5 Trunk Finisher, LCI LED Tail Lamps, Bruce Miranda v6.1 cable, 3M Shadowline Blackout tape, 6K Interior LED kit, Self Design Quad Exhaust (Center Resonator delete,
Magnaflow 10791 Tru - X Stainless Steel 2.5" Exhaust Pipe, Vibrant 1793 Stainless Steel Bottle Style Resonator, Yonaka Stainless Steel Dual Exhaust Tips), H&R Sports Springs 29146-1
Vendors Used for Installation-
Body Kit- BMW of Fairfax, Fairfax, VA
Quad Exhaust- Monroe Brakes And Exhaust, Fairfax, VA
Wheels and Tires- Hogan & Sons (Good Year), Ashburn, VA
Tints- LA Tint, Manassas, VA
Self Design Quad Exhaust- HPS Customs, Glen Burnie, MD
H&R Sports Springs- Authority PitStop, VA
Self Installs- MGP Caliper Covers, RPI Air Scoops, BMS Power Box, Angel I Bright 3.0A, R1 Premium D/S Rotors, Hawk HPS Pads, M5 Trunk Finisher, LCI LED Tail Lamps with Bruce Miranda v6.1 cable, HID 6K Fogs with Canbus Ballasts, 6K License Plate Lights, Stealth Matte Black Grille, 3M Shadowline Blackout tape, 6K Interior LED kit.
Retired:
Umnitza Quad Exhaust
I will sure try this. But, can i recode KGM with the original KGM trace instead of empty .MAN file?
#23
Hello - did you get any further with this. I've retro-fitted some folding mirrors to my E61 (LCI 2009) and done all the coding as per this post (VO, CAS, LMA & KGM) but the mirrors won't even tilt, much less fold. I'm not sure if there is a problem with the mirrors I bought (although the fit perfectly with the right plugs) or if I've just missed something in terms of coding. Any advice ??
Stormcrow
12-01-2019 02:09 AM
stillak
06-15-2015 09:51 AM
TexaZ3
05-06-2015 09:54 AM
