BEIKLAPPEN_B_KOMFORTSCHL has been set to aktiv, but mirror not folding from keyfob
My Ride: OEM Specs - Titanium Silver, Steptronic, Premium Package, Cold Weather Package, Premium Sound Package, Dakota Black Leather, Dark Poplar Wood trim, Xenon Adaptive Head Lights, Navigation, Satellite Radio
Mods: Umnitza M5Tech Body Kit(Front, Rear and Side Skirts), Alufelgen 19/8.5 ET35 (Front) 19/9.5 ET35 (Rear), Continental DWS 245/35ZR19 (Front) 275/30ZR19 Rear, MGP Red Caliper Covers, RPI Air Scoops, BMS Power Box, FormulaOne Pinnacle Tint (VA Limits), Angel I Bright 3.0A (Bright White), R1 Premium D/S, Hawk HPS Pads, M5 Trunk Finisher, LCI LED Tail Lamps, Bruce Miranda v6.1 cable, 3M Shadowline Blackout tape, 6K Interior LED kit, Self Design Quad Exhaust (Center Resonator delete,
Magnaflow 10791 Tru - X Stainless Steel 2.5" Exhaust Pipe, Vibrant 1793 Stainless Steel Bottle Style Resonator, Yonaka Stainless Steel Dual Exhaust Tips), H&R Sports Springs 29146-1
Vendors Used for Installation-
Body Kit- BMW of Fairfax, Fairfax, VA
Quad Exhaust- Monroe Brakes And Exhaust, Fairfax, VA
Wheels and Tires- Hogan & Sons (Good Year), Ashburn, VA
Tints- LA Tint, Manassas, VA
Self Design Quad Exhaust- HPS Customs, Glen Burnie, MD
H&R Sports Springs- Authority PitStop, VA
Self Installs- MGP Caliper Covers, RPI Air Scoops, BMS Power Box, Angel I Bright 3.0A, R1 Premium D/S Rotors, Hawk HPS Pads, M5 Trunk Finisher, LCI LED Tail Lamps with Bruce Miranda v6.1 cable, HID 6K Fogs with Canbus Ballasts, 6K License Plate Lights, Stealth Matte Black Grille, 3M Shadowline Blackout tape, 6K Interior LED kit.
Retired:
Umnitza Quad Exhaust
The Mirror sure has folding capability. When i dismantled the mirror to paint it titanium silver (originally black) to match my car color, i could see the power folding mechanism in place. Can you please let me know how the folding part looks so that i can confirm if mine has folding or not.
Thanks
Thanks
Sorry man ... my mirrors are mounted ... as others said just add BEIKLAPPEN_B_KOMFORTSCHL to either KGM (for cars build > 9/'05 otherwise to each door modules) after adding $430.
BTW, did you re-code your KGM after adding SA430 option?
Retired:
Yes, i did recode KGM.
I thought i should see CAS trace file once. So, i read CAS (it threw an error), and the trace file got refreshed. I opened it and searched for BEIKLAPPEN_B_KOMFORTSCHL and found one. This was set to nicht_aktiv. I changed this to aktiv in .MAN file and wrote this back to CAS (threw an error again). After writing, i read CAS again. Now in the trace file, i see BEIKLAPPEN_B_KOMFORTSCHL set to aktiv.
Still the mirrors do not fold. Should i have Window Close enabled too for the Mirrors to fold?
Hi SU530IX
As I all ready did write to you , coding must also be done to doormoduls ! ( TMFT & TMBF ) , it will NOT function before these moduls have got the SA430 code as well.
In order to make the mirrows folde over the remote ( long press on the key ) the BEIKLAPPEN_B_KOMFORTSCHL function must be set to "aktiv" when coded in Car Key Memory sesion
BenAnd
BenAnd
How did you re-code KGM?
Threw an error? That's not good as somethin' not setup correctly w/ the program ... obviously if all good & completed it should not throw any error.
No, as I said (and the others too) BEIKLAPPEN_B_KOMFORTSCHL is all you need aside from SA430 but some car already has that option.
BenAnd,
His car is post Sept. 2005 so no longer has TMFT/TMBF door modules all the door modules funtions has been moved to a single KGM module.
But same step to make it active just on a single module.
Hi SU530IX
BenAnd
BenAnd
Retired:
KGM read/write did not throw any error. Eventhough CAS read/write threw error (COAPI 1043), TRC got refreshed. I changed BEIKLAPPEN_B_KOMFORTSCHL from nicht_aktiv to aktiv in .MAN file and could write back to CAS. I can say that it worked because, when i read CAS again, i saw BEIKLAPPEN_B_KOMFORTSCHL set to aktiv.
Have attached Original KGM and CAS TRC files before mod and after mod.
Thanks gurus.
Thanks gurus.
