Backup camera
I'm trying to find the power signal lead for the backup camera. I decided to install the backup camera with the Xcarlink and I have to tap from the + wire when the car is put in reserve so the camera starts. Currently, I have the power coming from the rear back up light and this signal is not stable enough or either has interference causing the display to roll with horizontal lines. I'm told I can just install a relay in the current configuration and it will clean it up.
Hi tony, i'm trying to do the same to after successfully installed my xcarlink. I found this info for the relay and thought it may help you.
http://www.e90post.com/forums/showthread.php?t=425343
