auxillary heating; HUD
Hi everybody.
I'm looking for some time now specs, how to upgrade my e61 (535dT, production 03/2005) with:
- auxillary heating: which parts exactly do I need. If I read ETK correctly I need items 1,2,6 and 7 from:
http://bmwfans.info/parts/catalog/E60/Seda...pendent_heater/
- HUD upgrade. Here I need (I presume) all of this: http://bmwfans.info/parts/catalog/E60/Seda...ead_up_display/. But...:
- would I also have to replace the dashboard, or can I just have the hole cut out where it is already marked?
- is it necesarry to replace the front glass?
BR
BR
My Ride: G30 M550i
Model Year: 2018
As far as the HUD retrofit, it can be done but is a major project. Take a look at the following post and some of the ones that follow it:
https://5series.net/forums/index.php?s=&...st&p=742871
Location: Frankfurt/Main/Germany,originally from south Italy
My Ride: 2010 BMW 530i E61, alpine white, cream-beige interior, sports-auto-transmission and a lot more-
I think you have to change the dashboard and the windscreen,because cars with HUD need a special windscreen with a foil inside the glass.
You need also everything rewired and not to mention the costs...
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Rudy' post='1033043' date='Oct 15 2009, 04:35 PM
Yes, there is a special windshield but if you follow the link I posted above, you'll see that it's not mandatory, just recommended. As far as the cost, that's clearly an issue but the OP may have hit the lottery or something...
What about auxillary heating? Can anybody state if I stated correct parts and that there is nothing missing?
BR
Ivano, great avatar!
It can be done and it has been done by two European members.
Hopefully I will be the third.
You can easily cut the dashboard
You can fine the part list here:
https://5series.net/forums/index.php?showtopic=69022
forza azzurri!!
btw:sorry for whoaring
Originally Posted by vekkuli' post='1043544' date='Oct 30 2009, 12:56 PM
What? Your HUD dosen't work? Have you tried to code with NCS expert?
I don't have it yet Vekkuli.
When I will retrofit it, once installed everything obviously I will have to add the code in the FA then program, by NCS or by SSS+file.
Can't understand your reply
