aux in fitting
My Ride: 640D MSPORT GT
![Smile](https://5series.net/forums/images/icons/icon7.gif)
hi ,just been fitting the aux in prior to reprogramming. can some one show me where the plug and socket x13812/3 are located
I BELIEVE IT IS behind the dvd/cd slot how do i get easy access to this connection
this link by lomag will show you how to remove the panels and get to the mask ,ccc which you will (silver)see under the cd dvd drives.
http://forums.e60.net/index.php?showtopic=5650&hl=
unscrew the 2 screws on the bottom of mask, ccc and it will slide out.
you will add the 3 wires to the black plug that is already within the big plug. you will have to remove the 3 wires from the aux in part you ordered and place the in the correct holes in the black plug within the big plug.
blue/white pin 7
red/white pin 2
brown/white pin 8
http://forums.e60.net/index.php?act=Attach...e=post&id=10898
blue/white pin 7
red/white pin 2
brown/white pin 8
blue/white pin 7
red/white pin 2
brown/white pin 8
blue/white pin 7
red/white pin 2
brown/white pin 8
