For the audio buffs
Old Feb 11, 2010 | 08:37 AM
cleung's Avatar
Hey guys,
I just read through this thread from DIY mobile audio board and there are some pretty elaborate bmw installs. This install on a 535 with logic7 caught my attention because the installer took apart the L7 amp and tapped into the signal after the logic7 processing and before the amplifying. Has anyone thought about doing it this way yet?
http://www.diymobileaudio.com/forum/...-bmw-535i.html
Old Feb 11, 2010 | 01:20 PM
subterFUSE's Avatar
Sounds rather complicated.
I went with an Audison BitOne processor which accepts the speaker level outputs from the Logic7 amp. Sounds great.
If you want an even better solution, I think you can get the MoBridge? With that you tap into the fiber-optic output from the headunit before it gets to the Logic7 amp. You completely bypass the Logic7 processing that way, which is a good thing.
Old Feb 11, 2010 | 01:59 PM
cleung's Avatar
I just got an email from MObridge adn their DA1000 is out but you also need the bit-one, they said $700 MAP for the DA1000. That plus the bit-one together is way more then I want to spend. The DA2000 won't be out till this summer, which has the analog and digital output but will be even more money. Motus labs also has a unit out that is like the DA1000 and bit-one combined but I think I saw saomewhere that its worth $1500-1700.
I wonder how it will sound if I just input the high level speaker lines into the high level inputs of say a audison SRx5, will that work?
Old Jun 15, 2010 | 02:39 AM
Nick71's Avatar
Here the link to Motus lab product http://www.motuslab.com/en/productsa...iogateway.html
I think the price it's around $1000
CHRGRS_BMW
38
Sep 1, 2016 09:39 AM
bestofthebest
Jan 5, 2016 07:47 PM
4WheelSteel
Detailing Forum
Sep 3, 2015 07:18 PM
DetailersDomain
Detailing Forum
Sep 3, 2015 07:08 PM
Phurocious
Aug 20, 2015 09:21 AM
