Asking for CIC coding tips
My Ride: BMW 525I E60 01/2004
Hi everyone,
I have a 2004 525i E60, and i've done the CIC retrofit, but i have here two issues, that someone may already have also stumbled upon.
I have a OBD Ediabas cable with which i've been doing all the codings i need, but i'm a bit new on this, so i'm sure i should be missing a few steps here.
First issue and the more annoying, installed the CIC with the emulator option, and the navigation worked well for a couple of days, but now it's not working and it's only showing the coordinates:
Latitude: _º _ _' _ _"
Longitude: _º _ _' _ _"
And the second issue,is that in the services to be done i have two unidentified, one that shows <?>? that is 7.000km until it has to be done, and other that doesn't show nothing with 38.000km. Does someone know what services are this ones? and how to get them identified?
Thanks in advance to everyone who reads and tries to help!
Best regards
Best regards
The CIC was introduced when a few CBS entries were removed from the list and thats the reason why your CIC is showing blank entries. You need to code your car with the CIC installed.
As for the Nav not working with the add-on module, can't comment.
Thanks for the reply!
I already made the process car coding function on ncs expert and i think it already did the coding, but the unidentified fields remains there! Is there any specific coding method i should use?
Best regards
Make sure that you have added the CIC $6VA into the FA, also make sure that the build date is 0310. Then code the KOMBI with the default values using NCSExpert. Those missing fields will then go away.
And did you let the new production date on the car VO? or after coding the KOMBI you changed it back to the old production date?
Best regards
Glad you got this sorted. I wouldn't keep the VO date anything besides what it was originally. Because the next time you code an ECU it may take the changed date and give you some unexpected results.
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
Thanks a lot once again for the help!
Best regards
My Ride: MY2007 (01/2007) E61 530d Sport Futura 231 hp - Sport automatic gearbox - GPS Pro - HUD - Air Conditioning, automatic with extended features - bi xenon adaptative headlights - Night Vision - TV Function DVB-T - Active Cruise Control - Panoramic glass sunroof - PDC F&R - Active Steering - Sport Steering Wheel - HiFi Pro Logic 7 - Bluetooth + telematics - Electric fr seats with driver memory - Alarm ...
Hi,
Is it possible to know the complete coding has to do for replace a CCC by CIC not pre-coded bought used?
How to enter VIN, FA...?
Because pre coded are very more expensive !!!
bruce_miranda
04-15-2015 03:25 AM
