Again.... Passenger Airbag Malfunction Error
My Ride: 05 530D sport, CB, beige leather.
Is the same fault with the airbag an seatbelt warnings on the idrive..?!. If so then I have the same problem, but ice ordered a bypass from eBay so see how it goes....
My Ride: BMW
well just like everyone else I have the same problem, except mine turned on when my batter died lol. while were on this topic, does anyone know if this can be cleared/reset using the carly for bmw app
My Ride: BMW
Check your battery connections and make sure they are tight. If it's too loose, it will cause a high resistance. Make sure you clean your contacts before you tighten it.
Also, the error won't really clear itself. You have to use INPA or something similar to clear the codes. If a loose battery cable is in fact the problem, the codes should not come back.
Good luck!
ucsbwsr
26
Feb 26, 2025 08:22 AM
