Aftermarket brake pads and rotors suggestions? What about the brake s
I'm bringing my car in for new tires and was thinking about changing out the brake pads to get rid of the ever so famous BMW brake squeaking. There is about 70K on the car and the brakes were fully changed out at around 40K due to the same squeaking that of course came back within a month of the full brake service of all new pads and rotors. It's funny because I hear the exact same squeaking on at least every other BMW 5 series E60 that I see!! I think I may be able to get away with just pads so I was looking for aftermarket brake pad suggestions and, if needed aftermarket rotor suggestions. It's a 530 sport and she's not ridden hard. Just something that would be fairly equal to the factory performance, without the factory OEM price would be fine with me. Also, will I have to buy those 'brake sensors' that (I read) may be causing the incessant squeaking? Is there one sensor for the front and one sensor for the back, just two total? At the moment, there is ample pad width left on both the front and back pads.
AXXIS Deluxe pads?
What else?
Thanks for any suggestions.
AXXIS Deluxe pads?
What else?
My Ride: 05 530i
87 325is
85 VW GTI
I have 7,000miles on my axxis deluxe pads with out any squeaks. Have you tried spraying the back of the pads with anti squeak?
My Ride: 2004 (07/03) 530i, Mystic Blue Metallic, Beige Leather, Premium Package, Sports Package, Steptronic, Adaptive Xenons, euro red reflectors, K/N air filter, Falken 452's
Originally Posted by acribb' post='875384' date='May 11 2009, 05:23 PM
Well, I figured I might as well replace the pads if they are going to pull them off anyways.... Just to confirm, when you say the back of the pad, do you mean the part of the pad that actually touches the rotor?
Bavarian Autosport http://www.bavauto.com/shop.asp has a selection of inexpensive pads, plus they have this-
"Noise Free Brake Squeal Silencer - 4 oz.
Reduce that annoying brake squeal with Noise Free. Noise Free helps to dampen the vibrations that cause brake squeal. "
This is what you need.
My Ride: 05 530i
87 325is
85 VW GTI
You spray it on the side that does not come in contact with the rotor. You can get it at any parts store for around $5. You should pick some up anyway for any future brake jobs you plan on doing. Spray it on the day before installation for best results. Although you can install after 20 minutes.
My Ride: 2006 Titanium Silver 550i, with all the bells and whistles!!
Originally Posted by NeRwEEzy' post='875637' date='May 11 2009, 07:33 PM
for rotors, the most popular ones we have are premium rotors that are custom drilled and slotted ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Awest91
09-17-2022 11:05 PM
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
TexaZ3
05-06-2015 09:54 AM
