Active Autowerke "Active Processor"
Active Processor
E87 135i, (E90,E92,E92) 335i, E60 535i
$695.00
Active Autowerke is pleased to release a New Active Processor to the public. This is a "piggy back" ecu for the 335 ,535, and 135 model BMW. This unit replaces the Xede unit we had introduced with Chip Torque a year ago. Be assured all BMW Xede units in the field from Active still has the Active and Chip Torque support.
Same Great Taste, Different Packaging
Feeding our appetite for new and superior technology, while achieving economical pricing is the name of the game here at Active Autowerke. In an effort to accomplish that we have established a new partnership with AEM (Advanced Electronic Management), a US leader in electronic technology, enabling us to bring even more for less to the BMW marketplace. The new Active Processor features Digital Technology with 3-d mapping capability that allows you to maximize your potential gains while making sure your car is still running well within its "safe" limits. The Active Processor also has the capability to be uploaded on the workbench without a wire harness. All that is required is a USB cable and a PC with the included upload software. We?ve has also implemented a map switching feature which allows you to switch between maps. Whether it is a custom map or our basic Stage 1.5 performance map, the Active Processor?s Map Switching capability will handle the job over and over again. The new Active Processor also includes a custom harness kit with detailed installation instructions and comes preloaded with our Stage 1.5 software on our proprietary V3 firmware that is compatible on all current production 335, 535 and 135's. When it comes to Horsepower gain, the Active Processor produces over 65 HP and over 85 ft lbs of torque.
Key Features
Proven Horspower and Torque gains.
Compact Size Unit
Valet Switch included at no extra cost. Pre-Wired for your convenience
Full Control Over Fuel and Boost parameters and Ignition
16 Bit, 25 MHz CISC Processor
255 MHz FPGA Timing Shift
Over-current Temp Protected high current multi-purpose ourpouts
Capability to easily upload new maps with USB and PC
3-D Mapping Technology
Plug and Play Type Install Using Factory BMW Pins
Unit Completely Reversible
Easy to Install
20% + Increase in Power over Stock
Performance Specs
Torque : 70+ ft lbs. of torque (Stock Exhaust) Expect Higher gains when equipped with AA Exhaust and Intercooler upgrades
1/4 mile : 11.9-12.9 (Depending on an array of variables)
Power : 55+ RWHP (Stock Exhaust) Expect Higher gains when equipped with AA Exhaust and Intercooler upgrades
Link:
http://www.activeautowerke.com/viewp...x?id=Product73
Dyno:
http://www.activeautowerke.com/popdyno.asp...pg&text=E92 335 Active Processor
$695.00
Key Features
Compact Size Unit
Easy to Install
Performance Specs
Link:
Dyno:
Hiace
E60 M5 Discussion
11-09-2015 11:50 AM
th3h1ghlander
10-09-2015 07:40 AM
