67M (E46 M3 19") rims: would they fit?
Old 03-29-2012, 12:58 PM
Bebitoo's Avatar
Hi,
Need some advice from the rim fitment experts out there.
Love 67M, would like to retrofit a set on my E60. From my researches / understanding / computations:
- rears would be a direct fit,
- front would require 30 or 35 mm spacers.
Am I right? Should I be prepared to experiment some issues? What about center bores, for instance, are they the same?
Will post some pics and data right next...
David
Old 03-29-2012, 01:18 PM
Bebitoo's Avatar
My stock rims are 135M. Specs are as follow (square setup):
- rims: 8,0x18 ET 20, tires: 245/40
19" regular rims for the E60 are 172M. The rims do fit, obviously. Specs are:
- front rims: 8,5x19 ET 18, front tires: 245/35
- rear rims: 9,5x19 ET 32, rear tires: 275/30
Here are the rims are considering: 67M. Specs are:
- front rims: 8,0x19 ET 47 (would go down to ET 12, using 35mm spacers), planning on 245/35 front tires
- rear rims: 9,5x19 ET 27, planning on 275/30 rear tires.
What do you guys think?
Attached Thumbnails 67M (E46 M3 19") rims: would they fit?-135m.jpeg   67M (E46 M3 19") rims: would they fit?-172m.jpeg   67M (E46 M3 19") rims: would they fit?-67m.jpeg
Old 04-05-2012, 01:51 PM
Bebitoo's Avatar
Nobody?
Was my wording clear enough (as you probably guessed, English is not my mother tongue)?
David
Old 03-06-2013, 05:06 PM
johnbennett103's Avatar
My Ride: M5 SMG
This is a great post. My 545i is on its way, and I am going to put my m3 wheels on it. It is going to look great.
Old 03-06-2013, 05:25 PM
TLO03's Avatar
My Ride: alpine white 535 E61
Model Year: 08
http://www.willtheyfit.com
Old 04-07-2013, 06:13 PM
My Ride: M5 SMG
I mounted my M3 wheels this weekend, and they look great. I used a total of two spacers for 35mm at the front, and I also used a 20mm on the back (my rears were ground down to fit my e36 m3). They now look flush on all four wheels, and the ride is tighter. I will post pics soon.
Old 04-08-2013, 01:33 PM
Bebitoo's Avatar
Totally forgot this thread. Thanks John for bringing it back to life.
Here are some pics of my setup (still missing the little M stickers though).
Chose 30mm spacers on the front. Reference is S90-7-30-002, from Eibach. Perfect material, no issues whatsoever. 30mm is quite conservative, puts the wheel barely as a stock 172M. 35mm would probably look better, and I guess w/o any rubbing issues.
I have no spacers on the rears so far. Again, specs on these 67M rears are almost the same as 172M rears, so I guess stock 172M would look the same, in terms of "flushness" (never had the opportunity to stand to a E60 with 172M so far). That's not aggressive at all, some 20mm spacers would probably just make them look the way they should. Can't wait to see your pics John. Any rubbing issues?
Old 04-15-2013, 05:17 PM
My Ride: M5 SMG
Looks really good. Its unique without being too over the top. I had my wheels on my 1995 M3, and while it looked okay, the car handled poorly. Just too much tire for the e36 chassis. On the e60, these wheels feel much more at home. No rubbing at all, but still on stock sport suspension. Lowering in the near future. I promise to post pics soon.
One question - are you running stock sport springs or something else?
Old 04-16-2013, 06:55 PM
My Ride: M5 SMG
Here are two pics. I hate uploading with an iphone!
Attached Thumbnails 67M (E46 M3 19") rims: would they fit?-photo-12-.jpg   67M (E46 M3 19") rims: would they fit?-photo-17-.jpg
Island Road
07-09-2015 10:13 AM
Tonemapper
07-05-2015 01:08 PM
IndyRedBeast
07-04-2015 01:59 PM
BurtonSnol3order
07-03-2015 09:28 PM
shervinj
07-02-2015 07:29 PM
Quick Reply: 67M (E46 M3 19") rims: would they fit?
