545i 18" sport rims/tires to 20" rims/tires
I just replaced the oem sport wheels/tires to 20" wheels/tires and the 'run-flat' light came on. What can I do to disable the 'run flat' light while running on 20s? Thanks in advance for any suggestions.
on your i-drive system hit the main button twice and the screen will come up which will allow you to select vehicle settings under this menu is the mean by which you reset the runflat light. The rest is pretty self-explanatory. Follow the prompts on the menu and you will reset your tire pressure monitoring system so as to memorize the pressure that you've set in all four tires and as result when any of the tires begin to run low then you'll be alerted to that. If you don't reset this then the tire pressure monitoring system is nonfunctional and you can have a flat tire without the system of giving you warning.
PrimeTimeTSA
08-15-2015 02:14 PM
