295/25/20 Tires... will they fit
First off my name is Adam and I've been a lurker for a couple years. Learned a lot from reading everybody's posts but even after searching and reading this tread ( 20" Wheels ) I cannot find a definite answer to my question.
Question: Will this setup work on my FIVE?
Here is my setup:
2010 535i Sport Pkg.
Wanted: Vossen VVS-CV1
Proposed Front
Wheel = 20x9
BS = 20mm
Tire = 245/30/20 Nitto Invo
Proposed Rear
Wheel = 20x10.5
BS = 27mm
Tire = 295/25/20 Nitto Invo
Thanks everybody. I hope to learn enough to provide some useful info in the future.
Here is my setup:
Proposed Front
Wheel = 20x9
BS = 20mm
Proposed Rear
Wheel = 20x10.5
BS = 27mm
Yes, they'll fit. They are in fact the recommended 20 inch rear tire sizes for our cars. That said, I wouldn't want to roll on 25 series tires - wheels cost a lot to repair. That's why my rears are 275/30/20 instead, more meat on em.
what John said, if im correct 25 will be like rolling on rubber bands, which is fine if you like thin thin rubber and have zero potholes.. I wouldnt get them personally. Keeping 30's on my wheels is hard enough and although I have never bent a wheel from it, I have caused bubbles in the tires and even flats...
Good Luck though
![Getlost](https://5series.net/forums/images/smilies/imported/getlost.gif)
Good Luck though
Thanks guys. Here is a link to the Nitto website and their dimensions ( Nitto ) this may help others as well.
According to their website:
275/30/20 = 26.50" height
295/25/20 = 25.79" height
This tells me that the 295/25/20 has 0.355" less sidewall than the 275/30/20. I'm not sure if the 25 series tire will be that much different than the 30 series but I will let you know once I get them.
Thanks again for reassuring me about the fitment.
My Ride: 07 530 Titanium Silver Sport/Premium PKG OEM Mtech Kit
That what I recently have right now 285/30/20 in the back lowered on H&R sport and they are perfect with no fender mods. Can imagine 25's in the back.
I'm running 295/25/20's on the rear of my 545. No issues whatsoever. They ride just fine, but you definitely need to what for any potholes or such, as there isn't much tire to protect from bending the rim.
Bank$hot530
07-12-2015 04:36 PM
BurtonSnol3order
07-03-2015 09:28 PM
