285/25/20 n 245/35/20 question
My Ride: Bmw 530d 2004
Can't tell for sure about would it rub. How wide is the wheel?
285/25/R20 diameter is almost the same as the stock overall diameter, but 245/35/R20 in front is an oversized tyre. So it would look goofy. I suggest you go 275/30/R20 for rear to have some more rubber to protect the rims. Or if you want to stick with the 285/25, then you should go 245/30 in front to have the (almost) same overall diameter.
- Antti -
- Antti -
10in wide.. i was thinking to put 285/25 to make the rear lower. dont' want to run 245/30 up front due to the road condition.. guess i'll stick with 275/30, since the front tread is still good.
aqualibrium
07-21-2015 03:11 AM
