2005 headlights upgraded to 2010, what needs to be done?
Hi everyone im totally new to the 5 Series BMW. I just picked up a 2005 530i which i noticed came without the Xenon projector head lights and non led tail lights. I want to upgrade my lighting. I'm swapping out a set of 2010 head lights and tail lights and i wanted to know if it will be plug and play.
My plan is to: Put my head lights and tail lights in the 2010
Put the 2010 headlights and taillights in my 2005
Please give me all input and what will be nessary for both swaps.
Also whats this LCI i been reading about??
Thanks everyone.
Thanks everyone.
First you spend nearly $2,000 on the OEM headlights. Secondly you spend another $1500 or so for the dealer to run wiring and reprogram your car for LCI.
In other words, its not worth it. LCI is Life Cycle Impulse. Every few years cars upgrade existing models with a LCI to freshen them up.
Rear LCI tails are possible for far less cost.
1) Get your OEM (don't get replica) LCI tails for about $600-1000 (lower end if you're lucky)
2) Go to www.mironics.com and buy the plug-and-play kit from this guy in the UK for $409. Reputable seller.
Plug, play, install, enjoy! (This only works with rear lights)
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
I got my lci headlights for $850 and it included everything. the harness is $40. the wiring is easy it just takes time. You will be fool to pay the dealership to installed them, just used them for coding which is 1hr labor at about $150 tops or better yet use ncsexpert and coded yourself.
Regarding buying only the lci tailights, Its $530 from a couple vendors here.
I would talk to john@motorcepts there in queens richmond hill they do alot of lci upgrades and they code it for you, i hear that its very fairly priced shoot him a pm or call him
My Ride: BMW E60
Model Year: 2016
+1000... got my headlights for $500 from here including D1S bulb & ballast, harness for $40 and did the re-wiring & coding by myself and what a result ... ![Dance](https://5series.net/forums/images/smilies/imported/dance.gif)
You're pricing is wrong!!!
Thanks for all your input. Didn't know this was gonna be so expensive especially since i got the oem headlights and rear tail lights for $400.
Do you have the number or address for john@motorconcepts?
Can I ask where you got the lci headlights from?? is that for a pair or each?? I've got a 2005 530i and I think that it's D2S xenons. Does that mean I need to get new ballasts and control units and also new D1S bulbs as the Lci runs on different lights and control units??
Which vendors do the rear lci tails on this forum??
Thanks.
Thanks.
Hes on the forumsyou can pm him 126-10 89th ave richmind hill ny 11418
