2 Channel Amp for 2x SWS Earthquakes
Recently I have replaced all 4 midranges with Logic 7 midranges and also aded Logic 7 tweeters to the front doors/rear shelf.
The sound is soo much clearer and the treble is actually present now.
One small issue is that now, the bass is pretty much gone.
I know the underseat subs are wired in parallel to the front door midranges and the standard audio door speakers are more "bassy" than the L7 ones.
I'm not looking for something to blow your brains but more on the lines of 2 x SWS-8 Earthquakes, under the seats (instead of my 6.5" factory) and a 2 channel amp.
1. Can anyone recommend a decent 2x150w RMS 4ohm 2 channel amp? Like Alpine MRP-F300 perhaps?
2. Would this JBL GT5-A604E which is rated 2x160w RMS in bridged mode, be too much since the Eartquakes are only 150w RMS?
3. What kind of signal input does the amp need, low level or high level?
4. Would the gain would be too insignificant to justify the price?
5. Could I just tap into the current sub cables for the amp inputs or would I need to get it from the back of the head unit? And if I need the head unit cables, is it just the front door speakers since they are wired in parallel with the under seat factory subs?
The Rockford Fosgate Prime R300-4. Great amp to drive the subs and fits in the space over the left wheel arch too.
My Ride: 2006 530i mystic blue
pdx-5 the 75x4 would really mean like 75 to each corner (speaker/tweeter) so those are on a crossover so i guess getting the watts split. sounds pretty. good. i have a alpine m6 running a single 10 in a sealed box too
Bruce that one looks good but it has low level pre-amp inputs only and my signal would be high level and amped only since I have standard audio (head unit driven speakers only/no amp or loom in the boot so cant use your amp DIY/Technic harness) would a LOC like this one be enough as input taken from the underseat subs and then connected to the front only RCA inputs on the r300-4?
Or you can you just solder RCA heads onto the new wires ran from the underseat subs?
Thanks.
Thanks Bruce, appreciate it ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
One last question on this matter, for various reasons I rather not take the dash apart to get to the back of the head unit for the remote turn-on wire for the amp.
I remember a long time ago seeing someone on the forums just hooking that up to a spare (and unsed) fuse in the trunk just above the battery, which only gets power when either the car is unlocked or when the key is in, can't really remember.
Do you know which one?
I would actually recommend have the amp on only when the engine is running - you don't want flat batteries. So take the remote turn on from the boot socket or fuse box that feeds the boot socket. See a DIY in my signature for that.
