15mm spacers on the front
My Ride: 2004 525i Executive
just wondering, has anyone tried 15mm spacers on the front wheels which has ET20 ?
ive ordered some already and i dont know if i have made a bad choice
also i have koni springs installed (1inch drop)
My Ride: Bmw 530d 2004
Originally Posted by borisnewn' post='945648' date='Jul 18 2009, 10:59 AM
regarding the first post, i was wondering if it rubs when i turn or when i have a load of people.
Originally Posted by Anzafin' post='945652' date='Jul 18 2009, 03:09 AM
15mm spacer with a ET20 wheel makes it ET5. Possible rubbing depends now on the width of the wheel. And if it's 8,5" wide, it will very likely rub. Maybe even with a 8" wheel too. Oh, and it depends on the tire size too, and if you're using the recommended size, again it would likely rub.
Originally Posted by borisnewn' post='945655' date='Jul 18 2009, 11:20 AM
yeh the wheels are 8inches wide and tyre size is 245. ![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
Imagine the wheel 15mm more out and you can see it will cause a problem...
![](http://forums.e60.net/uploads/1190106157/med_gallery_11805_1351_32277.jpg)
believe it or not i took my rear spacer (20mm) and tried it on one of the front wheel. turned it, drove around it abit, it was actually ok! i m pretty confident 15mm would be ok too
Originally Posted by forumballer' post='945885' date='Jul 18 2009, 03:04 PM
i would leave the fronts
![Noexpression](https://5series.net/forums/images/smilies/imported/noexpression.gif)
chadillac2000
42
09-13-2017 11:15 AM
