tire sizes - 17"
Old Jul 16, 2009 | 07:56 PM
ODB's Avatar
ODB
2005 530i with 17x8" wheels. My rear tires are worn out, but the fronts (Goodyear RS-A 225/50R17 all-season) are hardly worn at all.
I'm planning to replace the rear tires with a wider tire. I've never had different size tires before... is 245/45R17 going to work?
The choices seem to be Goodyear GT, Michelin Pilot Sport, or Pirelli Pzero Nero all-season. Any votes?
Thanks
Old Jul 16, 2009 | 08:08 PM
TEAM M's Avatar
Ya u can run that size no prob
Old Jul 16, 2009 | 08:12 PM
TEAM M's Avatar
Get the same tires all 4 I don't like mix matching chances your ride not going to run smooth or handling may be off
Old Jul 17, 2009 | 08:09 AM
vaca's Avatar
Thanks
I just put continental sport contact size 245/45-17 on my 2004 530i and they fit great and work great. Even though the size is numerically different than the OEM (225/50-17) the actual size is nearly identical.
Old Jul 17, 2009 | 11:17 AM
edkwok99's Avatar
Really? I have 17" 225/50/17 standard on my 535i.
I can just put 245/45/17 on it?
Are you sure the rubber isn't too wide for the wheels?
Do you have any pictures?
Old Jul 18, 2009 | 01:15 PM
ODB's Avatar
ODB
My understanding is the front and rears should be as close as possible in diameter, but having wider rear tires is desirable on E60s... am I off?
asinner
May 6, 2015 06:03 PM
SNYPRUSMC
Apr 28, 2015 04:14 PM
lowcg3
Mar 26, 2015 11:23 PM
HS_01
Jul 5, 2004 06:15 PM
Aska
Mar 12, 2004 04:55 AM
