ZF Lifguard or OEM tranmission oil - Changing Mechatronics sleeve
My Ride: 530i n52
Is there any difference between the ZF lifeguard6 and OEM transmission fluid besides the price?
I'll be changing the mechatronics sleeve this weekend. Also, how many quarts/liters will drain out of the pan?
My Ride: 530i
Engine: M54
I'd use ZF Lifeguard6. If you plan on recovering and reusing the transmission fluid that is already in the transmission, you should only need to buy one liter to 'top off' any fluid that you may lose. If you want to drain the fluid and replace, you'll need to buy 6 liters. You'll drain out about 5.5 liters.
https://5series.net/forums/diy-do-yo...thread-137584/
My Ride: 530i n52
My Ride: E60
Model Year: 2005
In all honesty, who thought up the idea of recovering fluid and re-using them. That's like reusing the jizz out of a condom to lubricate the next. ZF fluid cost money, but it won't break anyone that already has picked up a luxury performance vehicle. Expect to pay if you want to play.
http://www.revolutionautomotiveservi...s-Bulletin.pdf
My Ride: 530i
Engine: M54
But if you're closer to 50K miles on the fluid then yeah it is a no-brainer - put new fluid in.
My Ride: E60
Model Year: 2005
It depends on how many miles are on the fluid. If you just did two drain and fills 5K miles ago and suddenly your sleeve is leaking, as long as you handle the fluid in a spotlessly clean container why throw away $100.
My Ride: 530i
Engine: M54
Anyhow, good luck OP with replacing the sleeve. It's really not too difficult. Hopefully the thread I posted is helpful. cheers.
My Ride: 545i
If anyone is on a budget use these
http://www.ecstuning.com/BMW-E60-545...249/ES2523911/
Not too much more for OEM.
http://www.thectsc.com/index.php?p=p...=186&parent=50
Also check out Pelican Parts. Sometimes they come out cheaper.
