Xi Tire size??????
My Ride: 2008 BMW 535XI white
Originally Posted by jay bimma' post='1014486' date='Sep 22 2009, 11:55 PM
i though about the KW V3's as well and i just installed a set on my friends new 335xi coupe. the ride is awesome but insane pricing like you said. and with only 52k on my stock shocks i will probably just end up buying H&R XI sport springs for the couple hundred that they would cost since i do the labor myself to install them.
but i did some research, some people say you may need to cut the bump stop little, if not then your car will be almost sitting on the bump stop, but if you cut the bump stop, then your stock shock may not be able to handle, recommand aftermarket shock as well, maybe i am wrong, just what i got from research
hope this will help
i am in the market for wheels and suspension
but just got the Mtech front and side, waiting to get painted and installed, need to save up for next step
Here's a link to Drlev99 thread about his ordeal with H&R ...
http://forums.e60.net/index.php?showtopic=52664&hl=
Mine is also lowered on H&R but I did not cut the bumpstops and I've had it on for a few months now and so far so good.
https://5series.net/forums/index.php?showto...80575&st=15
i spent alot of time debating spring only or KW, of course only thing stop me from KW is the $$
My Ride: 2006 titanium silver metallic
Like new 41k
Cold Weather Package
I have 19x8.5 up front and 19x10 in the rear on my XI with H&R springs. I did not cut my bumpstops at the recomondation of H&R and have had no problems. The ride is rougher then stock on crappy roads (bumpy) but not horrible, on good roads it is golden.
My rear wheels are et38 and no rubbing issues.
asinner
05-06-2015 06:03 PM
HS_01
07-05-2004 06:15 PM
