Xenon headlight ballast
Ballast is attached/mounted on the bottom of the headlight housing. To see the ballast, you will have to remove the headlight from the car, flip it upside down, you will see this...
The smaller square thing is the control module for adaptive-headlight controller (ALC). I corrected this.
My Ride: 2004 545i
[quote name='pcy' timestamp='1319635689' post='1394034']
You are right, I corrected the error.
[/quote
How much is the bulb? I think I am having the same thing. One of my low beams turned pink.
[/quote
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
The bulb is around $70, but you have to change both so the life cycle and the color would match between the two!
Then to complicate the things further, half of my online research stats my takes the D2S. The other half states it takes the D1S. The owner's manual states take it to the "stealership" for the fear of "High Voltage Hazard" And the stealership states they are not which one I have; bring it in because they will have to look at it.
If you are willing to remove the headlight and familiarize yourself with the car parts, you can save a lot of money; otherwise, take some lotion to the dealer :-) pun intended.
The type of xenon (D1S) is printed very clearly on the ballast as well as the igniter. Look at the yellow sticker in the picture I posted - bottom right hand corner.
Thanks PCY
Vman33
03-14-2022 04:43 AM
umnitza
11-25-2015 11:10 AM
jluzbet
11-07-2015 01:25 PM
Bogdan7
09-23-2015 11:40 AM
