wth? how do I reset the damn e60 FTM?
My Ride: 08 Porsche 911 c2s, 01 BMW 740il, 05 BMW 525i, 06 Acura TSX navi
This thing has gone koo-kooo. Constantly showing up and when i check the tire pressure, the pressure is good.
WTH? I tried resetting it but don't see the option.
Can someone tell me please? This is driving me nuts.
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
1-From I drive menu exit all running functions(hit menu button next to joystick)
2-Push joystick.
3-Scroll to "service menu".
4-Scroll top menu to find FTM.
5-Highlight Box(orange) on to ftm.
6-press joystick.
7-Reset FTM.
here is where it gets tricky,its going to tell you that is "initializing" but ignore it and start driving.After u drive a couple of minutes exit service menu all together and it should stop. Remember BMW FTM doesn't have any sensors in the wheels it detects the and calculates pressure by wheel spin!!!!
Good luck!
You can't be moving when you reset and the car has to be on a flat surface or else the system won't get a proper reading. It does take about 5-10 secs. to reset.
Michael
Acute Performance
Michael
Acute Performance
Good luck!
Good luck!
ive found FTM is also sensitive to temperature changes. if you initially set the FTM on a cold day, then inevitably it will go off in the spring/summer since the air in the tires expands...and vice-versa.
My Ride: 2005 525i, 6spd manual, Premium pkg, Cold Weather pkg
It is my understanding that you can't be moving when you press "reset", but once it starts initiallzing you can start driving. Without TPMS, the car needs to be moving to get an accurate reading of "tire pressure". This is the case with my car anyway.
linxuan
E39 Discussion
Mar 22, 2015 06:16 AM
