Would anybody happen to know what this part is?
My Ride: 2008 550i Sport
I'm not sure if this is where my coolant leak is coming from, but the bottom half of it is damp from what I believe is the coolant I've lost. It's circled in yellow in the attached picture and has a tube/pipe that runs to the driver's side of the engine bay.
Any help is greatly appreciated.
Thanks!
Thanks!
![Please](https://5series.net/forums/images/smilies/imported/please.gif)
My Ride: 2006 BMW 550i
thats the vacuum pump, and they are known for leaking oil.
i had a mysterious coolant leak also. check your lower radiator hose where it attaches to the radiator, there is a coolant sensor that plugs in there, and the o-ring for it is known to leak. check while car is warm, since the leak is slow enough, that it evaporates and doesnt hit the ground.
My Ride: '10 535i, '08 X5 3.0, '00 528i, '98 M3
Model Year: 2010
Looks like there is an oring that seals the pump to the upper timing cover. This might be cause of an oil leak.
I just Googled that after reading your reply. Looks like I'll have to order an o-ring kit for that one, too. Thanks again!
My Ride: 2008 550i
Also check the coolant expansion tank vent pipe that runs along the top of the radiator. The hard plastic portion of the pipe develops cracks. I just replaced mine on my 08 550i, because it suddenly failed.
Been there, done that on my 05. fixed it by replacing the 05 with a MY 2010 Msport
