Window weirdness
Before anyone jumps on me, i did RTFM. Can't figure out this issue. I think it may be a mechanical issue.
The passenger side front window will roll up and down from the switch on the driver side. But on the passenger side front door, the switch will only roll the window up, but not down. When I try to get it to roll up, it sounds like the motor is going, but it isn't doing anything...
Any hints or tips? Do I have a bad switch or do I need to go replace the regulator and motor? Seems like when I use the driver side, everything runs correctly...
All I know is BMW windows always act weird as a standerd option from the factory I wish someone can help you with yours
I had so many issues and problems on my passenger side window but I didnt bother my self to check whats wrong with it cause Im selling it
lol... dxb... I'm beginning to suspect it's a switch, and not the motor or regulator since it seems to work properly from the driver side... At first I was thinking maybe there was some way to reset it... but I don't know.
There is a prove for this weirdness here a link for BMW owner thread
BMW windows Demon had reached your car you need holy water to wash your car and send him back to hell
http://www.bmwclubuae.com/forum/showthread.php?t=5054
Thanks, glad to know others have worse luck than I do...
I guess I'll just order a switch and try to replace it myself... anyone have a DIY link to opening up a door panel?
alienintelligence
09-07-2015 12:09 AM
