Will Non RFT tyres fit our rims w/o problem?
Originally Posted by AlwynMike' post='388704' date='Feb 8 2007, 04:41 AM
EU and other markets use the ABS sensors. Any real difference in the wheel revolutions (from opposite corners I think) causes the puncture alarm to activate. This is why it takes a while to initialise after changing tyre presures, as the car has to learn a "normal" tyre rotation. This is also why the puncture alarm doesn't (shouldn't!) activate until about 30% of tyre pressure is lost so there would be a significant difference in effective tyre diameter due to deflation. Simple, cheap, no extra sensors to buy, replace or have seperate batteries for, just a little extra software!
I suppose strictly speaking, it's not a Tyre Pressure Monitoring System, it is a Tyre Rotation Monitoring System!
I think there is a trade off here. The ABS sensors are indeed simple and has the advantage of no extra sensors to buy, replace or have seperate batteries for BUT it will warn you a bit late - don't you think? for the tire to lose circa 30% of its pressure before you are warned.
Any driver worth his salt would notice the misalignment before he gets the warning (for a deflated front tire). I would rather be warned as soon as the air pressure starts going down.
The key factor is rolling diameter and as schoolboy physicists know, for circular motion, angular velocity (speed of rotation) is inversely proportional to radius of rotation (wheel diameter) for a given linear velocity (road speed).
The system measures changes in rotational speed of one wheel in comparison all the others others and when the threshold is reached (not a pressure threshold but a diameter threshold), the indication will be given on the iDrive screen.
ABC
Originally Posted by aybeesea' post='388721' date='Feb 8 2007, 06:13 AM
It can't be pressure dependent because different wheels have different profiles and run at different pressures and will reduce in rolling diameter differently for different tyre architectures.
ABC
ABC
Originally Posted by the-oneil' post='388728' date='Feb 8 2007, 11:41 AM
My point exactly, and since the change in radius of rotation (wheel diameter) has to be significant enough to be sensed, the presure has to drop significantly before this change could be measured.
ABC
My Ride: 2004 545i SGM Steptronic Dinan CAI Dinan TB GTech Pro RR
ABC
[/quote]
Isn't this the same technology for the U.S. e.g. no sensors in the wheels? I'm sure this has been discussed extensively in the past but the reference to lack of sensors in EU E60 wheels raises the question. No special valve stems, etc. correct?
ABC
[/quote]
MY 2007 US models have TPMs in each wheel in response to US legislation. Prior to those models, the rotational technology was used.
ABC
Originally Posted by aybeesea' post='388731' date='Feb 8 2007, 06:46 AM
What is directly sensed is the change in angular velocity. We don't know the angular velocity change threshold and any required percentage pressure change would vary from tyre type to tyre type.
ABC
ABC
With sensors in the rims transmitting data as soon as your vehicle starts moving. and every 6/7 seconds afterwards. If there is a change by more than 3 PSI/.21 BAR an alert is issued. Moreover, Rim sensors sense tyre temperature and this data is also normally transmitted alongside tyre pressure.
I feel the ABS sensor technoloy is out of date, but cheap & convenient. Personaly, I would have wanted to be warned ealy enough of any loss of pressure or increase in temperature as I maybe able to stop - call a roadside assistance and MAYBE able to save my tyre for repair. I would not feel comfortable repairing a RFT after driving for many miles with it deflated.
Both systems work, but as you say, it's all down to cost and convenience. More expensive TPMs and arguably be able to repair a tyre or cheaper sensors and arguably have to buy a new tyre. Swings and roundabouts.
ABC
Originally Posted by aybeesea' post='388735' date='Feb 8 2007, 06:56 AM
Yes and no.
ABC
ABC
CertifiedOfficial
05-21-2015 12:42 AM
bestofthebest
03-30-2015 08:12 PM
