Why doesn't this button "work"
Hi,
I remember trying this button when I bought the car. The result was a huge airflow and cold air came out from all vents. But when I tried the button today the led did not go on and nothing happened. I do know that the AC is working since it comes somewhat cooler air when I turn down the temperature dial.
Any suggestions or tips?
/Knubblo
/Knubblo
The air conditioning normally doesn't work below 4 degrees Celsius. This has been true for several cars I've owned in the past. This is probably the reason for the Max button not working. Will have to try it when its below 4 degrees next time.
The "airconditioning" function is present as long as the car is running and the button with the snow crystal has been initiated. However, the use of the compressor to cool the air is reduced at lower temperatures, where there normally isn't necessary to cool the air. Somehow this disables the use of the automatic max. cooling function.
In situations where there is plenty of cold outside air, you do not need this function. When the Max-button is hit, the compressor will work at full throttle to cool down air, as it simultaneously quits sucking external air. This provides for the most efficient cooling of the interior.
I'm not sure at which ext. temperature the max function quits working, but it should definitely not pose a problem.
My Ride: (E60) 535D M-Sport (DMS)
A further question regarding the Air-Con/Climate. What is the rest button for & when does it work? I've pressed it a few times & nothing happens & the button does not light up. It's the opposite button to the Max one.
My Ride: MY RIDE is DA real .-) HAMANN 5 aka BLACK MAMBA born on 16/06/2005/delivered on 05/08/2005 as following:
530dA (steptronic), Black II (JET), leather Dakota auburn black, mapple trim, head-up display, dynamic drive, active steering, adaptive xenon headlights (auto levelling) with headlight washers, alarm, comfort seats with massage function, advanced A/C, big compartment armrest, aux-in, MP3, Logic 7, Radio PRO, CD in-dash+cd changer, power rear sunshades, rear airbags, park distance control, auto dimming folding mirrors, smoking package, shiny shadow line (individual), fold down rear seats, ski bag, sport suspension, run flats on �116-style� rims (Good Year NCT5+), cup holders, debadged, fire extinguishers, additional permanent power outlet, BMW coat hanger, trunk release button (installed by Hobi), GPS tracking device and a big thx 2 Iceman.
Mods done:
� Authentic HAMANN FRONT APRON Including ellipsoid fog lights Item-No.: 10 060 110
� Authentic HAMANN REAR SPOILER Item-No.: 10 060 130,
� Authentic HAMANN HAMANN ALUMINIUM PEDALS For cars with manual gearbox Item-No.: 80 099 100 81,00 For cars with automatic transmission Item-No.: 80 099 120
� Authentic HAMANN FOOT REST In aluminium For left-hand drive vehicles Item No. : 80 099 122
� Authentic HAMANN HAND-BRAKE LEVER In aluminium For left- and right-hand drive cars Item No. : 80 099 216
� Authentic HAMANN Idrive of alu (sorry this is the only one in the World) but you can have it in carbon fiber ,
� Authentic HAMANN EXCLUSIVE FLOORMAT SET In black with HAMANN logo in silver For left-hand drive cars Item-No. : 80 060 120 For right-hand drive cars Item-No. : 80 060
� Authentic HAMANN COVER FOR OIL FILLER CAP In aluminium Item-No.: 80 099 117
� Authentic HAMANN SPORT REAR MUFFLER 4 TAILPIPES Sport rear muffler with four round stainless-steel tailpipes ( � 76mm ) Item-No.: 50 060 111
� Authentic HAMANN new add-on for M pack rear with diffusor for quad pipes -AVAILABLE NOW (http://forums.e60.net/index.php?act=ST&f=22&t=30630&st=0#entry332409)
� ///M steering wheel w Pegasus logo (this will be also changed to three spoke sports)
� ///M pack rear
� HAMANN ECU upgrade 265 HP 608 Nm.
most improtant:
�real and working like a charm forumsbuy real LED tails and PIAA 4700k fogs!!! for HAMANN full front apron you need H3
� CustomAngels, Angel Eyes Brighter than stocks 10X, WHITE & (REd for shows).
� Authentic HAMANN LIGHT-ALLOY WHEELS DESIGN EDITION RACE 20"
Ultra-light forged 3-pieced light-alloy wheel, Cross-spoke-design,Spider in black, titanium, screwing,polished flange
DIMENSIONS : 9.0 J x 20 FA Item No.: 91 207 315
10.5 J x 20 only RA Item No.: 91 207 625
Recommended 20" Complete Wheel Set DESIGN EDITION RACE I went with most aggressive Combination A.10 FA 9.0 J x 20 / RA 10.5 J x 20 with tires: FA 245/30 ZR 20 / RA 285/25 ZR 20
� Authentic HAMANN LOWERING KIT 4 progressive sport springs Lowering by approx. 40 mm FA, 20 mm RA Item-No.: 20 060 125
� Authentic HAMANN TIRE - PRESSURE CHECK SENSOR SYSTEM
� Authentic HAMANN SIDE SILLS Item-No.: 10 060 120
� Authentic HAMANN REAL CF ROOF SPOLIER Item-No.: 10 060 235
� Authentic HAMANN AIRBAG SPORT STEERING WHEEL 3-SPOKE Three-spoke design w their SMG paddles (For assembly O.E. airbag in exchange)
� Authentic HAMANN sports mirrors (all functions)
!!!!!!!!!!!!!!!!!!! and of course !!!!!!!!!!!!!!!!!
E60.net Clings
Still to do list;-):
� Our Hobi's camera system from : ww.switchchange.com).
� Individual leather interior (auburn+auburn alcantara)... and drive with sheer drivin' pleasure ... until 2009/2010 F10 comes or E60 possibly a 540d V8 diesel early in 2009 badly juiced!
Originally Posted by Knubblo' post='253294' date='Mar 11 2006, 06:23 PM
Hi,
/Knubblo
/Knubblo
Originally Posted by IMU' post='253411' date='Mar 11 2006, 08:52 PM
It is the parked-car heating option which can release residual heat into the cabin after stopping the engine, not fitted as standard on UK cars but a retrofit may be available soon through Webasto
Are you sure its not fitted as standard in the UK? It works on mine as I can switch it on after stopping the engine. Maybe its true for the newer E60s now but not 2003/2004 models possibly???
Model Year: 2015
Engine: N55
Originally Posted by BMW530' post='253602' date='Mar 12 2006, 09:37 AM
IMU,
Mine is a May '04 build and it works. But it is only operative for a short time after you turn the engine off, then it becomes disabled.
