White Cloud of smoke starting up 545i from cold
Old 08-12-2008 | 08:49 PM
evo42's Avatar
White smoke following you down the road is definately a coolent leak. The head gasket typically is the cuprit.
Blue smoke on startup COULD be excess oil burning off, my 1980 911 used to do this and was deemed 'normal' as long as it wasn't too bad. Glad its looking 'up' for you. GL
Old 08-12-2008 | 10:08 PM
thomasj's Avatar
I'm picking it's not a coolant leak though, cause it doesn't look like water vapour...it's smoke. I don't think oil burning off in a 2004 545 is normal though aparently the PCV valve would cause smoke, soo fingers crossed!
Old 07-24-2013 | 10:13 PM
Mady Lee's Avatar
My Ride: BMW 545i six shift
Hey guys did replacing the pcv fix the problem? ??
Old 07-25-2013 | 01:02 PM
A B Able Truck's Avatar
My Ride: 2006 550I v8 N62tu
Oil consumption was excessive - It smoked - I was told I needed valve stem seals
My car (didn't pass smog & couldn't renew registration);
2006 BMW 550I – 92,000 miles – V8 (N62TU)
Smokes (white/gray/blue) – failed visual – Smog Report (15 mph – HC ppm Measured 91 – Max. 49)
Symptoms & history;
It used oil (approx. 1 qt. per 2-3 tanks) and I read the history of V8 valve stem problems (internet & local shop research), I was about to have the valve guide/stem seals replaced or drive the car off a cliff. But it didn’t have the classic symptoms of defective valve stem seals/guides. It also ran like a rapped ape (old school for ran great). I’m a heavy truck mechanic with old school car experience (35 years). The plugs were clean and the exhaust smelled funny, also the exhaust dripped clean water no matter how hot or long it ran. I pulled the intake throttle housing and noticed excessive oil. Replaced the (ccv) diaphragms in the valve covers (torn) & read up on the cyclone oil separator (like a Dyson vacuum). Because I wasn’t happy with the oil consumption & residue in the intake, I fabricated a Scotch Brite pad filter with screen for each valve cover vent outlet. As well as a pre-filter for the CCV diaphragm base. This cleaned out the oil residue and has greatly reduced oil consumption while allowing crankcase recirculation. I pulled the spark plugs and stuck a camera down a couple plug holes. Yes, the top of the pistons were loaded with carbon. So I sprayed Sea Foam in each plug hole, followed by a shot of low pressure shop air to help spread it around the piston. I let it sit for an hour or so, then reinstalled the plugs. I topped off the fuel tank with high octane and added 12 oz. of CRC Fuel System Cleaner (part #05063) to the tank. 100 miles later and what a difference – no smoke or water dipping out the exhaust after warm up.
****This note was copied from a BMW Technical Training manual
Note: If the exhaust system produces blue smoke, it is necessary to check whether the engine is also drawing oil into the combustion chamber through the crankcase breather, which suggest that there is a fault in the area of the crankcase breather. A clear sign of a problem is an oiled up clean-air pipe.
****The valve stem diameter was increase at a production point (you would assume) to remedy the guide problem. I don't believe BMW would use inferior stem seals after this change, if ever. My vehicle has now passed smog test & no longer smokes. I did have to run the proceedure twice before it lowerd the HC levels within specs. I will probably was the Chevron fuel treatment from this point on. (See attached TS It cost me $200 to fix compared to the $4000 > $5000 I was told it would take for a guide/seal replacement.
SI B 13 05 06 & SI B 13 01 07
**** Day 35 - 1200+ miles later NO smoke or excessive water from tailpipe - It also **** Does not need any oil ****
For those of you seasoned mechanics replacing guides & seals - This worked for me - my vehicle - my situation - but I believe you should diagnose each vehicle on an individual basis - Regardless of BMW guide/valve stem history.
ETNav382
04-24-2015 07:29 PM
thesalboy
04-08-2015 09:13 AM
md750i
04-08-2015 09:13 AM
08-12-2003 11:41 AM
06-17-2003 09:38 PM
Quick Reply: White Cloud of smoke starting up 545i from cold
