What's this little sucker?
Old Jan 29, 2006 | 08:32 PM
  #31
w8pmc's Avatar
My Ride: (E60) 535D M-Sport (DMS)
Originally Posted by AC_S5' post='231660
Oh I jsut checked... I do have that little bugger!
Maybe its a accelerometer!!!!
That's it, it measure the speed of your car by windspeed.
[/quote]
I noticed this on my new car that i collect today & after asking the question the dealer said he thought it was an external temp sensor. Reason i asked is that it's over twice the size on my car than the photo you've posted & the other E60's that were parked close by, so my guess is that the 535D M-Sport needs a larger one, although for the life of me i can't work that out. I'd hoped ot was a radar jammer or something. They do look a little overkill for a temp sensor, but if that's what they are then fine.
Old Jan 29, 2006 | 09:19 PM
  #32
EBMCS03's Avatar
Old sensors use to be inside the bumper blocked from wind... wonder why the E60s is right there in the air dam...
Old Jan 29, 2006 | 09:20 PM
  #33
miss525i's Avatar
My Ride: 2012 535i M Sport Package
did you find the little thingy? I couldn't find mine
Old Jan 29, 2006 | 11:01 PM
  #34
AC_S5's Avatar
If you look at the car from the front, it should be on the right side, under the radiator.
Old Jan 30, 2006 | 06:48 AM
  #35
EBMCS03's Avatar
Yup! Exactlly there...
Old Jan 30, 2006 | 07:13 AM
  #36
Bart001's Avatar
My Ride: X3 | 3.0 | 6-speed manual
Originally Posted by tab545' post='231615' date='Jan 29 2006, 06:45 PM
The only sense in which wind chill matters to inanimate objects is that they will approach the true temperature more quickly. If a car is warm and parked at 0 degrees with no wind (like in a garage), it will not hit 0 degrees for quite a while, due to the buildup of layers of warm air immediately around the car; but if that warm car is parked at 0 degrees and a 50 mile per hour wind, it will approach 0 far more quickly.
That's not "wind chill," it's simply heat transfer. It may be relative to the rate of change of temperature, but it's not relative to absolute temperature.
Old Jan 30, 2006 | 07:29 AM
  #37
MAK's Avatar
MAK
[/quote]
Help is on the way ! !
Old Jan 30, 2006 | 07:44 AM
  #38
JDN's Avatar
JDN
Because I had to replace mine three times from road damage in my 540-6. I likely would not have bought another 5-series if they had not moved it to a more protected area. I checked before I ordered.
Old Jan 30, 2006 | 07:57 AM
  #39
SkiScubaSailDude's Avatar
My Ride: 2011 F10 528i - Imperial Blue, Oyster/Black, Premium, Premium 2, Cold Weather, Xenons.
Here is were I found the answer to this in June of '04....
Whatduheck is this?
Old Jan 30, 2006 | 07:59 AM
  #40
big_ipaq's Avatar
These two treads should be merged then, right?
