If I disconnect the battery and touch the positive and negative terminals together? Someone told me that this will clear the system fault codes. :think:
I'm not sure if that is a good thing to do. Some of the models have auxillary battery to store the memory. I just found out about this so called battery and it is mounted on the rear drivers side fender well in the trunk. It actually looks like an amp rather than a regular battery.
Originally Posted by mels545
(Post 1318398)
Are you suggesting disconnecting the car from the battery terminals, and connecting the positive and negative terminals of the battery with a single wire? Because thats generally a bad idea even with a small battery let alone a car battery.
BANG!
Originally Posted by mercutio
(Post 1318652)
BANG!
When we get bored in physics labs we vaporize copper wires by laying them across car batteries. Literally it turns the copper from solid into a gas. |
he means touch the battery cables together, not short the battery terminals!
but I agree with the others, worked on older BMWs, but between the IBS on the negative cable and the pyrotechnics on the positive cable I wouldn't do it on the E60 |
i wouldnt do it. you are essentially shorting any capacitors that may be storing power.
