View Poll Results: What rims should I get for my winter tires?
Voters: 3. You may not vote on this poll
Rims can take many tire mounts if those are done right, which may be a problem sometime. If you are changing tires then having cheap steel rims (OEM) or other may not be a bad idea. You are paying about $20 to remount the tires plus time, if you can pick up rims (used or other) for $40-60 then you are even in two seasons, and can change them back and forth at your own schedule. I would get a set of cheap rims, just for convenience.
TexaZ3
05-06-2015 09:54 AM
bestofthebest
03-30-2015 08:12 PM
