What is this plug from?
Old Dec 17, 2018 | 07:13 PM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
Default What is this plug from?
Tonight I took off the lower aluminum reinforcement plate under the front subframe for the first time and found this plug sitting on it. Anyone know where it goes? Looks like a plug for a drain hole or something. Also found a clip for the air filter box but that one was easy to take care of.
2009 535xi 6mt wagon.
Old Dec 17, 2018 | 07:28 PM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
Which aluminum plate? The stiffener plate under the subframe?
Old Dec 17, 2018 | 07:29 PM
kd7iwp's Avatar
Engine: N54
Yes. A previous owner would have dropped it and it fell on the aluminum plate under the engine. Took it off to change front differential fluid.
Old Dec 21, 2018 | 02:07 PM
kd7iwp's Avatar
Engine: N54
Bump. I guess no one has seen one of these before? I’ll try on an E90 forum in case it’s a part that’s N54 specific.
Old Dec 21, 2018 | 03:32 PM
Sirius815's Avatar
My Ride: e61 535xi
It is on my automatic tranny by the flywheel. It allows access to the bolts that hold the torque converter to the flywheel. On a MT car I haven't seen this cover before, but it may be for the N54's MT.
Old Dec 21, 2018 | 04:37 PM
kd7iwp's Avatar
Engine: N54
Oh right, most cars have a plug on top of the flywheel to check if it is at TDC. I’ll look to see if that’s the case.
Old Dec 22, 2018 | 01:33 AM
Sirius815's Avatar
My Ride: e61 535xi
No, not on top. Next to the oil pan, I think on the passenger side.
Old Dec 22, 2018 | 06:14 AM
kd7iwp's Avatar
Engine: N54
Oh, okay. I noticed an opening at the bottom of the bell housing where I could see the flywheel so that must be for TDC monitoring, but it was a square hole. I didn't look on the sides but next time it's up on ramps I'll check. Thank you.
Old Dec 24, 2018 | 05:34 AM
gman6262's Avatar
My Ride: 2010 535xiT Touring, N54, Individual Audio
Model Year: 2010
Engine: N54 3.0L Twin Turbo
The c shaped deflector on the plug is oriented towards the ground when you reinstall.
Old Dec 26, 2018 | 05:45 PM
kd7iwp's Avatar
Engine: N54
I looked up the par number and according to this diagram (part 9) it looks like you certainly are correct as it shows it next to the oil pan. Thanks.
