WHAT IS THE IDEAL RPM ON IDLE?
Old 01-14-2006, 07:35 AM
Fireplace's Avatar
Hi All, how do you tell if the RPM on idle is set to the optimum for your E60? What is yours? Mine seems to be at 0.6 mark. Is this considered low?
Old 01-14-2006, 07:40 AM
Ricracing's Avatar
Originally Posted by Fireplace' post='224131' date='Jan 14 2006, 06:35 PM
Attachment 14301
That's normal.
Mine idles at 600 rpm also, when cold at about 800.
Old 01-14-2006, 07:51 AM
znod's Avatar
While something of a simplification, warmed-up idles for a 545i are 500 RPM with climate control off and 700 RPM with climate control on.
Old 01-14-2006, 08:24 AM
1600's Avatar
My Ride: 2010 M5 alpine white, black full leather, etc.
Originally Posted by Fireplace' post='224131' date='Jan 14 2006, 11:35 AM
Attachment 14301
According to the SM at Hassel Motors, Freeport, NY, there is no real "normal" rpm at idle. It is controlled by the engine's computer. Of course, wild fluctuations may indicate something wrong going on, however a mininal amount of variation from day to day should not be a cause for alarm.
Old 01-14-2006, 08:32 AM
BetterMakeWay's Avatar
Does the idle rpm have anything to do with how quiet the engine is or how smooth at idle? Thinking that bmw engines are very smooth and quiet at idle more or less because of the lower idle rpm.
Old 01-14-2006, 08:40 AM
1600's Avatar
"Normal" idle, I would tend to believe, should be both smooth and quiet .
Old 01-14-2006, 09:03 AM
Other cars have the idle rpm higher like at 800 rpm.
Old 01-14-2006, 09:36 AM
Peter530i's Avatar
THIS IS PERFECTLY NORMAL !!!
if you want higher revs at iddle press the the AC compressor button
Old 01-14-2006, 09:57 AM
Memotronic's Avatar
the question is
Does the car moves when gear is in D Mode and petrol is not applied " same as in the posted pic above "
for me sometimes it moves and sometimes it did not move ?? is our e60 heavy car ?
Old 01-14-2006, 10:17 AM
P.S.B's Avatar
Originally Posted by Memotronic' post='224221' date='Jan 14 2006, 10:57 PM
the question is
hmm .. i think i understood what you said and it normal for the car to move when in 'D' mode with gas pedal not hit .. i think its kind of weird of it does not move unless your on an uphill ramp
Quick Reply: WHAT IS THE IDEAL RPM ON IDLE?
