What happened? What happened?
I was just on te expressay and suddenly I heard a pop from my engine area and my battery light icon was illuminating from my insrument cluster and suddenly the air went off and the car began to shut down. What could have happened?
Could be the alternator just died, if it did check to see if the belt actually moves. Sometimes when the alternator dies it seizes the pulley and then the belt may be there but unable to actually turn the alternator.
After the pop was there any noticeable smoke? Any smells? If you don't see or smell anything immediately open the fusebox under the hood and check the relays, one may have blown, which would be best case scenario since relays are typically way cheaper than alternators.
After the pop was there any noticeable smoke? Any smells? If you don't see or smell anything immediately open the fusebox under the hood and check the relays, one may have blown, which would be best case scenario since relays are typically way cheaper than alternators.![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
No there was no smoke but the only smell I noticied was the one from me
![Hyper](https://5series.net/forums/images/smilies/imported/hyper.gif)
Bogdan7
09-23-2015 11:40 AM
