What gas do you use?
Shell V Power - 91
We also have a husky and esso that offers 93 octance for the same price as all the other premium fuels but its said that they have bad gas...
My Ride: 2004 BMW 530i
Originally Posted by pjinca' post='983788' date='Aug 20 2009, 04:27 PM
Same as 91 in NYC, dunno about FL though.
I usually use Shell V-power 93 octane with Nitrogen but someone told me that they add 15% ethanol to it. That seems a little high and
makes me wonder if I should switch to a different brand.
My Ride: 2004 530i
Originally Posted by pjinca' post='983758' date='Aug 20 2009, 04:14 PM
Well, if your car maker "recommends" 91 then you're fine using 89 if you want. Problem is BMW requires 91+ octane and using the lesser grades ill probably void the warranty if a problem develops with the engine. I use 91 octane - usually 76 or Shell, sometimes Costco -but NEVER Arco, Valero, or the other cheapo ones.
Originally Posted by theXman' post='983800' date='Aug 20 2009, 04:38 PM
The key word is "recommend". I don't believe it's required. But using higher octane would have slightly better engine performance based on prior discussions.
and you use...
Page 170 of my manual states:
Fuel specifications
The engine uses lead-free gasoline only.
Required fuel
Premium Unleaded Gasoline
The minimum octane rating is 91.
If you use gasoline with this minimum octane
rating, the engine may produce knocking
sounds when starting at high outside temperatures.
This has no affect on the engine life.
Minimum octane rating corresponds to the Anti
Knock Index AKI and is determined according
to the so-called (R+M)/2 method.
Do not use leaded gasoline, as otherwise
the lambda probe and catalytic converter
will be permanently damaged.<
Use high-quality brands
Field experience has indicated significant differences
in fuel quality: volatility, composition,
additives, etc., among gasolines offered for sale
in the United States and Canada. Fuels containing
up to and including 10% ethanol or other
oxygenates with up to 2.8% oxygen by weight,
that is, 15% MTBE or 3% methanol plus an
equivalent amount of co-solvent, will not void
the applicable warranties with respect to
defects in materials or workmanship.
The use of poor-quality fuels may result in
drivability, starting and stalling problems,
especially under certain environmental conditions
such as high ambient temperature and
high altitude.
Should you encounter drivability problems
which you suspect could be related to the fuel
you are using, we recommend that you respond
by switching to a recognized high-quality
brand.
Failure to comply with these recommendations
may also result in unscheduled maintenance.<
Fuel specifications
Required fuel
high altitude.
brand.
Fuel specifications
Required fuel
high altitude.
brand.
Fuel specifications
Required fuel
high altitude.
brand.
Originally Posted by mbp727' post='983809' date='Aug 20 2009, 01:49 PM
I've always thought that car manufacturers "recommended" higher octane fuel which was really a bunch of bull s***. I recall the "new lessees" meeting at lexus a few years back where the lexus rep told all the new owners that if we plan on lowering the octane we needed to bring the car by so they could reformat or flush or something like that, but going up in octane was fine with no re-anything.
