What do you use to lift up the front of your E60 so you can work under
Old Feb 19, 2012 | 12:10 PM
pukka's Avatar
My Ride: 2008 535i: (8/07 Build) Metallic Bronze, Beige NASCA Leather, Ventilated Seats, Sport Pkg, Cold Wxr Pkg, Logic-7 Sound, HUD, Night Vision, PDC, Split Rear Seats, NAV, Premium Pkg, Comfort Access, HD Radio, Sport Auto Trans Current mods: M-Aero Kit, JB4, Motorcepts 6000k HID Foglamps Umnitza ICE-Lite 10w LED 6000k AE's 1992 Camaro RS: Fully Restored w/Custom Interior, 5.0L V8, T-tops, OEM Z28 Foglamps, Inst Cluster, & Spoiler, Custom Sound, Too many engine mods to list
Not enough clearance to use Rhino Ramps.
Was thinking about fabricating some sort of "step" board to get enough height for the ramps or just using two hydraulic floor jacks.
I'd appreciate any input from someone who has already done this.
Old Feb 19, 2012 | 12:42 PM
SD5Series's Avatar
My Ride: 2007 ★ Alpine White
hydraulic jacks work good.
Old Feb 19, 2012 | 01:00 PM
vkhong's Avatar
Model Year: 2010
I used a piece of 2x10x14 lumber to add 1.5-inch ground clearance. I had the older gray Rhino Ramps.
Works well for my E60 Sport and E90 Sport.
Old Feb 19, 2012 | 01:30 PM
inktoxicated's Avatar
My Ride: 2006 530i mystic blue
29.99 jack from pepboys. honestly i was looking at that jack that comes with the car, either its missing a peice or im just retarded, but i have no clue how to use it
Old Feb 19, 2012 | 09:52 PM
gcvt's Avatar
My Ride: 2008 550i - Sport Package, Sport Transmission, Active Steering, Navigation, Comfort Access, 7 Logic Stereo
I use 2x4 scraps to get it up on the ramps. Works like a charm.
Old Feb 19, 2012 | 10:53 PM
e6t.lab.rat's Avatar
There's a jacking point under the engine (you should see a black flat rectangular jack pad) Maybe you can jack up from there then slide your ramps under the wheels.
Old Feb 20, 2012 | 04:54 AM
DavidF's Avatar
My Ride: 545i sport
I use a floor jacka and jack stands. Really, every DIY'er should have a floor jack and stands. Much easier than ramps.
Old Feb 20, 2012 | 06:17 AM
luigi524td's Avatar
Had similar problem getting my Roadster up on mine ... built these out of 2x8's.
Attached Thumbnails What do you use to lift up the front of your E60 so you can work under-car-ramp-boosters.jpg
Old Feb 20, 2012 | 09:47 AM
pukka's Avatar
Thanks for the responses - the pics of the wooden boards was exactly what I had in mind.
Old Feb 20, 2012 | 09:54 AM
pukka's Avatar
It all depends on what you are doing. Obviously if you are taking the wheels off then a jack and stands are necessary. But its definitely easier to drive on to ramps than it is to spot and lift each side using a jack and then place the stands.
BTW I do have them though
