What is the correct tire pressures?????
My Ride: [i][b][u]Since 19 august 2004[/u][/b][/i]: [color=red][b]530i[/b] High Executive[/color], Silvergray with beige interior, Popular wood, Servotronic, Sportssuspension, electric foldable and dimmed mirrors, dimmed interior mirror, pappelmaser braun wood, cupholders, styling 123 18" wheels, Logic 7, Steptronic, alarm class 3, electric sunscreen in the rear and suncreens for sidewindows, Comfort seats, heated seats, Xenon with headlightwashers, Adaptive corner lights ALC, Advanced airconditioning, lightpackage, Nav Pro, 6 cd changer, side airbags rearseats, bluetooth siemens S55, chrome kidneys, gearlever with wood, voice recognition retrofit, front windshield with green band.
Waiting for trunkopener button from Hobi :)
Originally Posted by Jimbo' date='Sep 8 2004, 08:46 AM
I went over this with my dealer (SA & techs) and they recommended 36psi all around. They said the tires would last longer and ride fine.
Originally Posted by 530E60NL' date='Sep 8 2004, 07:48 AM
[quote name='Jimbo' date='Sep 8 2004, 08:46 AM'] I went over this with my dealer (SA & techs) and they recommended 36psi all around. They said the tires would last longer and ride fine.
Yes, 18" dunlap run flats, and I don't know. Maybe someone else can help.
From what I gathered from the manual, it recommends 29/36. The techs said the the 29 is good for hard cornering/driving. Daily driving at 36 all around and the tires will last longer.
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by 530E60NL' date='Sep 8 2004, 04:48 PM
How much pressure is that in BAR by the way??
Just kidding...
It's: 2.48 !
I thot more like 6.89
32 x 6.89 = 220
36 = 250
Oops = kPa, same as chart on door jamb
Added for conversion help:
Conversion of Pressure Units to Atmospheres
ATMOSPHERE 1 atm = 1 atm
mm of Hg (torr) 1 atm= 760 torr
Pounds per square inch
1 atm = 14.696 lb/in2
Newton per square meter (Pascal) 1 atm = 101325 Pa
kilopascal 1 atm = 101.325 kPa
bar 1 atm = 1.01325 bar
mbar 1 atm = 1013.25 mbar
Inches of Hg 1 atm = 29.92 Inches of Hg
32 x 6.89 = 220
36 = 250
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
But the manual suggests a higher pressure for the rear?? Why is that?
Model Year: 2013
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
Maybe because the rear is where most of the extra weight is added like two to three passengers versus one or two and of course a trunk full of your goodies.
But I always drive alone.. So that should mean I would at least have a 50:50 pressure on the tires.
I guess that would make a better case for the same pressure. Are your tires the same size front and rear? Also, it could be a handling thing since the rear wheels drive the car. Bottom line is -- I don't know.
Bet you had figured that out already.
