What are the best shifting points
That is actually untrue. Someone did a quite detailed analysis of this and turns out the best shift point for a 550 I believe was 6200 or so.
Redline shifting is not always the best since it will not always optimize the time spent in the meat of the torque curve.
For example if you shift at redline through gears 1 to 2. Your revs will be higher in gear 2. If you shift at a lower rpm your revs in gear 2 will be lower. Therefore you want to shift at a point where it puts you into the meat of your torque curve however balance that with time-spent in the torque meat. So it is a bit technical but most cars are NEAR redline but you may want to play around with 1000k less than redline and move up from there.
On a 530 for example the ideal shift point is at 6800 and not the 7k redline.
use the smg launch control aka acceleration assist and it'll shift for you...should produce a good 0-60 time.
My Ride: 2006 550 SMG
I was thinking about that, but does it produce wheel spin on take-off?
however, the automatic upshifts feels much more brutal (and perhaps faster) than what we can achieve in manual mode, so maybe that'll make up for it.
i guess just try it and see what you think...
Ya if you dont have excellent grip... even with good grip it spins the wheels like nuts...
http://forums.e60.net/index.php?showtopic=29075
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Do a burn out. I've become quite the expert these days with 465 lb-ft torque.
![Evil](https://5series.net/forums/images/smilies/imported/evil.gif)
ucsbwsr
09-19-2015 10:58 AM
