What the....
I had the valve cover off previously to change the gasket and was clean as a whistle in there. I did lift the engine and dropped the subframe. Removed the pan and cleaned it thoroughly. That's when I spotted the birds nest hanging out of the intake tube
I had erased the latest codes. Tried to retrieve and print them but need to update the software in the OBD2. Sheesh! I'll get them to you later. Or some brand new ones .
I used the synthetic oil flush you recommended. Worked very well. I want to remove the 2 tube screens again. They are probably clogged up again after the flush. Shouuld have done it before I put oil back in. I'll let you know what I find.
Appreciate your help , Dan
BlueHorse
12-18-2011 05:02 PM
