Weird taillight issue
Old Oct 17, 2008 | 09:00 AM
bespoke1's Avatar
My Ride:
I've noticed that my taillights strobe every so slightly, no real pattern, just slightly brighter and dimmer. strange, I know but I noticed when the car was warming up this morning.
Any ideas?
Oh, it's a 04 5451A
Thanks,
B
Old Oct 17, 2008 | 09:52 AM
flyingpuck's Avatar
Are they LED taillights?? If so they will "strobe" on startup while the car is checking its systems!
Old Oct 17, 2008 | 09:56 AM
Gene's Avatar
Could be the bulbs getting close to dieing...
Old Oct 17, 2008 | 09:59 AM
bespoke1's Avatar
My Ride:
could be a led thing i guess. they all dim and bright in unison so i don't think that they would all die at once.
Old Oct 17, 2008 | 10:00 AM
bespoke1's Avatar
My Ride:
I'll have to check again once the car has been running a bit....
Old Oct 17, 2008 | 01:10 PM
luigi524td's Avatar
Thumbs down
Any ideas?
Oh, it's a 04 5451A
Thanks,
B
Check the bulb sockets and connectors for corrosion or moisture. Make certain that vibration has not loosened either. Use come bottled air (PC air spray) to eliminate any moisture; I don't know how these junctions feel about dielectric grease to protect the bulb socket or connectors.
If a bulb has a broken filament that may also cause some flicker but I'd think the Light Control Module would detect that ... and last but not least - if that module is beginning to fail, remanufactured modules might be available for a price that is more reasonable than new (Unless Garry's discount is a better deal).
Old Oct 17, 2008 | 01:40 PM
bespoke1's Avatar
My Ride:
Thanks for the tip, i will dig in there this weekend and see if there is any corrosion or loose parts.........
Bank$hot530
Jun 23, 2015 03:41 PM
BilboTeabaggins
Jun 11, 2015 08:00 PM
indigof
May 21, 2015 10:31 AM
james69z28
Mar 23, 2015 06:45 PM
jmnieves
Jun 6, 2004 11:09 PM
