Weird misfire N54
Old Nov 9, 2021 | 08:24 PM
Crumb's Avatar
My Ride: E61 535xi
Default Weird misfire N54
Been having trouble with misfires
This car is completely stock except for a BMS chargepipe, and DCIs.
This issue began with constant misfires on Cylinder 4 which was a result of the teflon seal on the injector literally missing. I then replaced sparkplugs, coils, and injectors but and still having problems.
the car starts and drives just fine now until you put some load on it (get into boost, hills, normal highway accel, etc. ) then it stutters and shakes and barely accelerates. If it does this enough it then deactivates cylinder 4 until i either clear the code or restart the car. Im getting 29CD0 and nothing else.
i have replaced coils, sparkplugs (gapped), injectors (index 12, coded), and now as a last desperate attempt a HPFP. I am out of ideas as to what could have happened.
ive already tried moving coils and plugs around even swapping to one of the old coils. The misfire always stays in cylinder 4.
There is the tiniest knick in the wires leading to coil 4 however, the copper braiding in the wire was still completely intact they have been insulated with heat shrink and I do not think this would be an issue.
I am completely out of ideas as to what to do, any suggestions?
Old Nov 10, 2021 | 04:09 AM
Crumb's Avatar
My Ride: E61 535xi
bump for the morning
Old Nov 11, 2021 | 05:15 AM
neilv's Avatar
My Ride: E61 530xi 6MT
Engine: N52
When was the last time you walnut blasted the valves?
Old Nov 11, 2021 | 04:26 PM
Crumb's Avatar
My Ride: E61 535xi
it has been done recently. Who ever did it left the walnut media all over the side of the engine. When i replaced the HPFP i got a good look at the valves, theyre still pretty clean.
took it to a specialist and theyre stumped. They seem to think something is wrong with the DME. I have the MSD81 Index 3 DME. I will be replacing it as the next step.
marco211
May 10, 2023 10:30 AM
Christian Paul
Dec 7, 2019 04:39 AM
skeester
Jan 26, 2018 10:26 AM
Andrew06
Dec 29, 2015 12:06 PM
Texas_Vol
Sep 9, 2013 10:16 AM
