5Series.net - Forums
-   -   Weatherstripping maintenance (https://5series.net/forums/e60-discussion-2/weatherstripping-maintenance-132886/)
plowery21 05-11-2013 06:54 AM
I had a 2002 GMC truck for 10 years. The owners manual recommended maintenance included rubbing down the weatherstripping with a lube product recommended by GMC. It helped keep the weatherstripping flexible and last longer.
Is there such a product for BMW? I dont see it in the manual. A google search brings up a few options but wanted to see what 5series had to say first. Thanks
ETNav382 05-11-2013 07:18 AM
Gummi fledge, it might be spelt with a ph instead of an f though.
luigi524td 05-11-2013 09:11 AM
I just updated my supply @ Amazon ... it goes a long way! Amazon.com: Buying Choices: einszett 914806 'Gummi Pflege Stift' Rubber Care Stick - 3.4 fl. oz
plowery21 05-11-2013 10:40 AM
Thanks guys. Can you apply this stuff to the rubber seals around the rear window.. or just keep it limited to the door, sunroof and trunk weatherstripping?
luigi524td 05-11-2013 12:08 PM
It will treat and protect any rubber/natural-synthetic seal around doors, windows, etc. However, it is NOT intended for treating seals like o-rings and gaskets like those used in the oil filter canister etc.
plowery21 05-11-2013 12:23 PM
Thanks!
KS_Jayhawk 05-11-2013 04:25 PM
Stuff works great ;)
