Weak backup lights, any fixes?
Old 12-26-2004, 12:13 PM
pennetta's Avatar
I find that my backup lights are not strong enough to do any good. I actually keep my foot on the brake so I get the benefit of more light from the brake lights. Anyone know the wattage curently installed and can I go up to a higher rating? Do the Euro cars have better backup lights?
Old 12-26-2004, 12:19 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
There are many aftermarket backup lights. You should be able to find them easily on the web... (Sorry I don't have any links at this time.)
Old 12-26-2004, 12:20 PM
pennetta's Avatar
I would like to keep the car stock looking. I was hoping for a bulb swap.
Old 12-26-2004, 12:26 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
That's what I'm talking about...
Old 12-26-2004, 01:02 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
A quick search yielded many hits. Here's two that show what I'm talking about:
http://www.securityworld.com/lightin...genbackup.html
http://www.audiooutfitter.com/store/20106.html
Without looking, I can't say if the E60 uses the 1156 or 3156 type bulb. If not, I'm sure there are similar replacements for other bulb types...
Old 12-26-2004, 02:00 PM
EBMCS03's Avatar
The OEM back up lights are only 16W... 12V 16W putting in a 50W wouldnt that draw too much current?
Old 12-26-2004, 02:03 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I'm no electrician but in light bulbs, I think watts are a measure of light output, not currrent draw. It's amps that measure draw.
These bulbs are designed exactly for this application. I doubt they'll cause any problems...
Old 12-26-2004, 02:29 PM
EBMCS03's Avatar
Originally Posted by Rudy' date='Dec 26 2004, 03:03 PM
I'm no electrician but in light bulbs, I think watts are a measure of light output, not currrent draw.? It's amps that measure draw.
These bulbs are designed exactly for this application.? I doubt they'll cause any problems...
[snapback]72630[/snapback]
Right Watts is how they measure how bright the light bulb is... but Power = Current * Voltage
Which is Watts = Amps * Volts so with the same 12 Volts and obtaining 50 W instead of 16W, Amps need to be higher thus higher current draw. No?
Old 12-26-2004, 07:14 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
As I said, I don't know the formula, etc. but common sense tells me that there will be an increase in current draw with the brighter bulbs. The same common sense tells me it won't do any harm since these bulbs are designed for the exact application that we're talking about -- back-up lights.
What I'm not sure about is whether or not the car will scream at you if something other than what's expected is installed. It's possible that BMW is monitoring the circuit to alert you if a bulb fails, etc. If so, it might not like seeing the non-standard bulbs...
Old 12-26-2004, 08:36 PM
EBMCS03's Avatar
Alright pennetta buy it and try it and let us know... as I would too like brighter back up lights
Quick Reply: Weak backup lights, any fixes?
