the way E60 was meant to be
Old Jul 9, 2013 | 06:04 PM
  #531
Jawo26rski's Avatar
My Ride: df
I have the standard Hi Fi.
Old Jul 10, 2013 | 09:49 PM
  #532
andrey_gta's Avatar
My Ride: 128
How can I tell if e90 or e82 has this button? Where do the wires go from the DSC button? - because my DSC button looks different on the back
Old Jul 19, 2013 | 03:04 PM
  #533
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Originally Posted by b00sted415
Nice!!! This mod didn't trigger that check engine light for you did it?
Nah, I need to change the two O2 sensors (pre-cat) .
Old Jul 23, 2013 | 02:37 AM
  #534
jinsta's Avatar
My Ride: E60 30d, E39 35i
Model Year: 2004, 2001
Engine: M57n
Does the car need to be programmed 100% after buttons installed? bit of mix on feedback
I fitted the button yd and bar the 'sport' lighting up...not convinced its doing anything. I'm already remapped so maybe why don't nottice as much and only had a very short run so yet to to trial properly. On a pre lci 04 530d seAuto if makes a diff like
Old Jul 29, 2013 | 08:56 AM
  #535
mudspike's Avatar
I got all the stuffs ready and I have a question on wiring.
I got LED momentary switch as attached picture and I really want to avoid frying the module.
Can someone draw a line for dummy which line goes to where?
I am quite smart in making question though…
I watched ROSKINC’s youtube video and also learned from this thread that #10 is positive and #8 is negative.. and that's all I know
The way I want to set up switch is, leave the LED light off when sport mode is disengaged and on when sport mode is engaged.
Thanks
Old Jul 29, 2013 | 04:41 PM
  #536
Deb6orah's Avatar
My Ride: FGH
I think BMW does this to save time, time is money for them, you know.
Old Jul 29, 2013 | 05:02 PM
  #537
KOC's Avatar
KOC
My Ride: E60
Model Year: 2016
Thanks
8 -> C
9 -> (+)
10 -> NO
ground wire -> (-)
Old Jul 30, 2013 | 07:17 AM
  #538
mudspike's Avatar
Originally Posted by KOC
8 -> C
9 -> (+)
10 -> NO
ground wire -> (-)
I appreciate your input.
I will give this a try over this weekend.
Old Aug 12, 2013 | 11:42 PM
  #539
Matrix_tm3's Avatar
My Ride: 09 E60 ( LCI )
is it that simple in the LCI?? i cant get to know where those cables are!! and to be honest i'm not taking my chances!!!!
Old Aug 13, 2013 | 04:27 AM
  #540
Matrix_tm3's Avatar
Guys I found the unit in my LCI behind the glovebox, the thing is, it's way different than the one in the picture! :S mine is like twice the size and all wires are already there!
I removed the wires 7&9 anyways... And connected my own, and took the car for a spin,,, still! Nothin! I know it doesn't appear in the cluster,, but I couldn't feel any difference!what should I do?!
