the way E60 was meant to be
Old Nov 14, 2012 | 07:32 AM
  #41
Crckrjck's Avatar
Dangit, this sounds too easy not to give it a try. Guess i'll be ripping my dash apart this evening. I'll report back on shift points on the ZF automatic if someone else doesn't beat me to it.
Hopefully it doesn't require what's described in the attached pdf, but i'd be willing to go that far if we can get full confirmation of benefits
File Type: pdf
Last edited by Crckrjck; Nov 14, 2012 at 07:39 AM. Reason: spelling correction, added text and attachment
Old Nov 14, 2012 | 07:49 AM
  #42
BlaSTiWi's Avatar
You need to do page #10 and to get to the bottom of page #12.
Old Nov 14, 2012 | 07:56 AM
  #43
BLooD's Avatar
Still no proper clear instructions on how to install this. Whats the pin shorting for if your have the sport button installed?
Old Nov 14, 2012 | 08:17 AM
  #44
Crckrjck's Avatar
If i'm understanding correctly, the button shorts the pins briefly when you press it, thus enabling the feature, until the car is turned off. The button would have 3 wires, one to the ground, one to the contact that needs to be grounded to activate it and one back to a light on the button to tell you that it's on. You probably could get away with just 2 wires, no light, provided the dash does actually display Sport as described. I think i'll stop by Radio Shack on the way home and see what kind of buttons they have available.
Old Nov 14, 2012 | 08:23 AM
  #45
BlaSTiWi's Avatar
Yes, you just need pin #8 & #10 for at least turn it on ... pin #9 is the indicator light on the button.
Old Nov 14, 2012 | 08:25 AM
  #46
BlaSTiWi's Avatar
Pin shorting if you don't have the actual button.
Old Nov 14, 2012 | 08:30 AM
  #47
Crckrjck's Avatar
thanks for that info BlaSTiWi
Old Nov 14, 2012 | 08:32 AM
  #48
BLooD's Avatar
Oh ok, well I priced up the parts. £100 for the bezel and £42 for the button plus cable and pins. Bit much for me at the moment.
Old Nov 14, 2012 | 09:07 AM
  #49
pradden's Avatar
My Ride: 02/2006 525i Titanium Silver Metallic Manual 6-Speed
If you have a manual where would you install your "Sport" button?
Old Nov 14, 2012 | 09:30 AM
  #50
BlaSTiWi's Avatar
I don't think there's OEM way for manual ... AFAIK "Sport" button is not generally factory option for manual in BMW modem lineup ... I maybe wrong ... but no OEM shifter faceplate w/ "Sport" button listed in BMW parts list. So you have to go non-OEM look which basically get the best looking push button switch and locate the best place to put it.
Aside from heavier steering & less lag throttle in manual you can easily hold RPM on up/down shift as oppose to auto.
