Water pump?
My Ride: 535XI
Engine: N54
Water pump?
Yesterday i park at Mickey D got off my car and when i came back out i see vapor coming out the engine bay antifreeze was all over the floor.
I'm not sure if is the water pump or a hose.
Engine: N54
How did this turn out for you?
What was the leak?
What was the leak?
Check for a worn seal around your water pump. Then check around your radiator/fittings, and then hoses.
If you still can't find it, you can always pressure test the system or use UV dye.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
It definitely not the pump of you would not be still driving it. I would check the hoses (one of the ones at the pump usually goes first. Also check the expansion tank an sensors.
That's a fair amount of coolant. My radiator just failed but it was a bare trickle and I drove it for a week before the coolant level dropped.
My Ride: 535XI
Engine: N54
I remove the expansion tank no cracks and look under the car and see nothing.
i will buy distilled water and drop them in to check if it comes out somewhere.
fucking cold outside and now snow and ice everywhere
My Ride: 535XI
Engine: N54
Any one of you guys know what coolant hose could be on back of the engine?
I drop water into thw coolant line the one un the bottom of the expansion tank it was coming out from behind the engine.
Engine: N54
You drop water in where?
