Water pump?
1 Attachment(s)
Yesterday i park at Mickey D got off my car and when i came back out i see vapor coming out the engine bay antifreeze was all over the floor.
I'm not sure if is the water pump or a hose. |
How did this turn out for you?
What was the leak? |
Originally Posted by NoQuarter
(Post 1586945)
What was the leak? Maybe this weekend i will look into it. |
More likely a hose. If it was the water pump the car would have overheated.
Check for a worn seal around your water pump. Then check around your radiator/fittings, and then hoses.
If you still can't find it, you can always pressure test the system or use UV dye. |
It definitely not the pump of you would not be still driving it. I would check the hoses (one of the ones at the pump usually goes first. Also check the expansion tank an sensors.
That's a fair amount of coolant. My radiator just failed but it was a bare trickle and I drove it for a week before the coolant level dropped.
(Post 1586966)
I remove the expansion tank no cracks and look under the car and see nothing. i will buy distilled water and drop them in to check if it comes out somewhere. fucking cold outside and now snow and ice everywhere |
Any one of you guys know what coolant hose could be on back of the engine?
I drop water into thw coolant line the one un the bottom of the expansion tank it was coming out from behind the engine. |
You drop water in where?
