Water got into Micro Power Module
#31
The car definitely WON'T need any programming. Mine burnt out earlier this year and I replaced it myself. The hardest part is getting that nasty a$$ burnt popcorn smell out of your car.
I received your PM and I will be happy to help however I can.
#32
My Ride: Coming soon...
This is a major design flaw in my opinion. Why on earth would BMW place electronics in one of the few places water can collect? Retarded.
#33
My Ride: 540i
Model Year: 2017
+1
If you're still having trouble then you may need to cut/splice in a good connector with 6 inches of wire in place of your old/burned one.
The K-CAN bus communicates over this same wiring harness and if damaged won't allow the MPM to turn on the:
Front Fuse Holder:
F34 10A CCC/M ASK
F35 5A NAV
F36 7.5A Comfort Access & Door handle Modules
F38 10A CD Changer
F40 10A DVD Changer
Rear fuses that feed the MPM are:
F57 20A
F52 10A
F60 7.5A
Provided your car is a Sept '05 build or earlier. From the pictures I've seen you've had a meltdown. Check the connector to the MPM
and the wiring leading away from it. A lot of amperage flows through this harness. Make sure there isn't any funk in the connector
or insulation melted on the wiring.
http://www.bmw-planet.com/diagrams/r...0e61/index.htm
Good luck! Keep us posted!
Front Fuse Holder:
F34 10A CCC/M ASK
F35 5A NAV
F38 10A CD Changer
F40 10A DVD Changer
F57 20A
F52 10A
F60 7.5A
#34
My Ride: 2006 530i Sport package- Sapphire black
I did purchase some electrical cleaner and sprayed it all over the melted area. The connector is now and clean for the most part but no luck yet.
#35
My Ride: 540i
Model Year: 2017
Here's an excerpt from http://www.bmw-planet.com/diagrams/r...0e61/index.htm
Switching on terminal 30<57
In the following cases, the relay for switching on terminal 30<57 is activated:
the first time the power supply is applied to the micro power module
when there is a voltage level at the input of terminal 15
terminal R is ON
on locking or unlocking the vehicle
on opening or closing the luggage compartment lid
on opening or closing a door
Switching off terminal 30<57
In the following cases, the relay for switching off terminal 30<57 is activated:
when the starting capability limit of the battery is reached
if the number of ?Wake-up signals? reaches a threshold of 30
when there is an undervoltage (U < 9 V) with bus activity for a period of time greater than 60 seconds
when the remains awake after a period of 60 minutes.
quote http://www.bmw-planet.com/diagrams/r...0e61/index.htm
You are familiar with at least part of this from your previous post.
Maybe you've exceeded the 30 threshold of wakeup signals or your car is not going to sleep. Not sure if an OBD reader or indie can reset this.
I'll keep digging. Hopefully someone with knowledge will chime in
DON'T GIVE UP!!!!
#36
The wiring looks good. And the mating area looks as good as the back of the connector?
terminal R is ON
I'll keep digging. Hopefully someone with knowledge will chime in![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
DON'T GIVE UP!!!!
terminal R is ON
DON'T GIVE UP!!!!
I'm thankful to have fellow members willing to help and taking time of their busy schedule to just post and assist someone in need. I will keep trying
#37
#38
#39
Any Help would be appreciated
Thank You!
#40
Car has to be programmed. I pulled a fried TPM out of my car today. Called my bro n law (BMW mech) and he said they all require programming. Said it would take a half hour (less for some of us).
